    Phono Pre Amp Before PAS2
    Rowbo1
    Phono Pre Amp Before PAS2 Empty Phono Pre Amp Before PAS2
    Post by Rowbo1 Fri Jan 28, 2011 9:39 pm
    I may have drove someone crazy over at the bottlehead fourum.
    Should I use my NAD PP2 phono pre amp between the TT and the PAS2.
    Dave
    Phono Pre Amp Before PAS2 Empty Re: Phono Pre Amp Before PAS2
    Post by Bob Latino Fri Jan 28, 2011 10:32 pm
    The PAS-2 has a built in phono preamp. Just plug the interconnects from the TT directly into the PAS-2's phone input.
    Rowbo1
    Post by Rowbo1 Sat Jan 29, 2011 12:38 am
    Thank you.
    ruffian
    Post by ruffian Sat Jan 29, 2011 7:20 pm
    There is no reason why you can't use the PP2 either. Just plug it into one of the line in (not the phono in). Then you can have fun comparing the PAS phono section to the PP2. Or run two tt... If you have a low output MC cart I think you will need the PP2.
      Current date/time is Fri Apr 26, 2024 2:40 pm
