Hello.My first tube preamp.It's a Pas3 it looks like no mods have been done.
The plan is to leave it stone stock.Can you hook up a cd deck to any of the imputs.
Thanks in advance for not rolling your eyes or audibly sighing.
A very "mild" mod is to connect 2 1n4007 diodes in paralell with the se rectifier. You can use the se as mounting points.badtuna wrote:
I'm happy that you will save one PAS3 for future generations. They are more and more scarce now.badtuna wrote:
Thanks for the comments.It sounds OK considering it's age,to me that is.
I'm will try some of the upgrades but I don't to do anything I can't put back
as it was.I think an original one these will be hard to find down the road.
That's why the unused inputs are shorted to ground.j beede wrote:I have never experienced crosstalk as I had with the PAS (PAS-2) series of preamps--I am talking about crosstalk between inputs, not L/R channels. I had my cable box connected to an unused input and could here TV audio as plain as day when I was using the phono input for music. I don't think the ganged selector switch in the PAS-3 is any different than what was in my PAS-2. I no longer have that preamp but if I recall correctly, it used simple hookup wire--not coaxial cable--between the rear panel and the selector switch.
