    PAS Filament current
    Scot_B
    Scot_B
    PAS Filament current   Empty PAS Filament current
    Post by Scot_B Sat Sep 28, 2013 7:05 pm
    I see that I can save on current consumed by switching up to the LED mod vs the standard bulb. Seems like a good move rather than replacing the old burned out bulb.  This has me thinking,  I don’t use the phono or tape inputs that belong to the PC-6 card, could I get away with pulling the 12AX7’s on it without modifying the PAS and achieve even better filament current savings and not adversely affect the line card performance ?
    PAS Filament current   Empty Re: PAS Filament current
    Post by Bob Latino Sat Sep 28, 2013 7:22 pm
    You could pull those 12AX7 tubes on the phono board - BUT - then the other two line stage 12AX7's would be working at somewhat higher voltages which *could* shorten their life. What I might do is put a couple of cheapie Chinese 12AX7's on the phono board and save the better (Telefunken original ?) 12AX7's that are on the phono board now.
    Post by Guest Sun Sep 29, 2013 4:09 pm
    Scot_B
    Scot_B
    Post by Scot_B Sun Sep 29, 2013 4:24 pm
    Seemed like a good idea... I think I'll leave the tubes alone, and just replace the burned out bulb with the LED kit...
    Thanks for the responses
    Scot
      Current date/time is Wed May 08, 2024 7:38 am
