    Bolt & Screw Sizes
    mazeeff
    Bolt & Screw Sizes Empty Bolt & Screw Sizes
    Post by mazeeff Sun Sep 13, 2015 7:54 pm
    Can someone give me the sizes of the following hardware, for a ST-70 chassis?
    1. Bolts to hold down both output and power transformers. Looks like 8-32, but not sure of length or head type.
    2. Screws to attach cage to chassis. Looks like a #6 self drive sheet metal screw. Is this correct?
    Mike
    evoroadster
    evoroadster
    Bolt & Screw Sizes Empty Re: Bolt & Screw Sizes
    Post by evoroadster Sun Sep 13, 2015 8:58 pm
    I just now finished mounting new output and power transformers into a SCA-35 chassis.  I used 8-32 1/2" long machine screws. Don't forget the star washers under the nuts.
    Post by Bob Latino Sun Sep 13, 2015 9:24 pm
    mazeeff wrote:Can someone give me the sizes of the following hardware, for a ST-70 chassis?
    Mike
    Yes - The transformer screws are all 8-32 screws. On a stock Dynaco ST-70 chassis the screws that hold on the bottom cover and the tube cage are #6 sheet metal screws. On all the VTA amps those screws are 6-32 stainless steel machine screws. The screws to hold on the tubes sockets and all the front face and rear face gear are 4-40 pan head screws.
    mazeeff
    Post by mazeeff Mon Sep 14, 2015 4:25 am
    Thanks for the quick responses.
    Mike
      Current date/time is Fri Apr 26, 2024 7:48 am
