Looking at a pair of used Tannoy D700's. They are 6 ohm nominal impedance and 3 ohm minimum impedance. Can my M125's handle them? If yes which would be better, 8 ohm or 4 ohm taps?
Are my amps compatible with these speakers?
LeGrace- Posts : 388
Kentley- Posts : 496
Looking at the Tannoy specs, and reading what others say about them, I would give an unequivocal YES to their use with M-125s. They are quite efficient at 93db...
As far as impedance, I would definitely recommend the 4 ohm taps. The current draw from 8 ohm taps might easily tax the output sections.
Rule of thumb (verified by a speaker maker of high repute):
Don't let your speaker impedance fall too far below amp tap rating. This can damage the amp, and further would tend to a wild, uncontrolled sound, esp. in bass. Like a hip-hop concert gone amok.
The M-125s are powerhouse amps, and as we all should know by now, 125 TUBE watts = 200-300 SS watts. Not literally, of course, but in the Real World.
Dogstar- Posts : 361
I'm envious of you for owning a pair of M-125's. They probably make any speaker sound fantastic!
I only posess an ST-120. Half the power but it's still a great amp. I own Polk Audio LSiM 703's, JBL L100T3's, and custom Klipsche's. And the ST-120 I have makes all of those speakers sound great though the 703's are not as efficient as the other 2 pairs so the volume is not as great. The JBL's are not the monitors. They are floor standing 3 ways. They sound very precise and the imaging is great. The Custom Klipsche's started off as Heresy's but the guy that built them used larger waveguides for the tweeters and mid ranges and crossovers based on Bob Crites designs. They sound very three dimensional and natural. The problem with the Klipsche speakers is that the finish looks very amateurish. Because of that I keep them in my bedroom which is also where the ST-120 is. McIntosh MC2105/C39 currently drives the JBL's in my den.
I'd suggest Vintage Klipsche or JBL L100T3's.
I want to bet that
I want to bet that
Its a toaster- Posts : 3
I just received a pair of 700s myself and I am running them on a vta st70. They sound amazing. A friend loaned me a pair of super tweeters to try with them and the improvement was fantastic. So yes your 125s will work just fine. I am getting ready to bi amp them soon and expect them to only get better. One thing I can warn you of is that the speakers are not forgiving of a bad source or source material so you may find yourself looking to upgrade your album or cd collection.
I did not reallize that Tannoy's were so expensive
Its a toaster wrote:I just received a pair of 700s myself and I am running them on a vta st70. They sound amazing. A friend loaned me a pair of super tweeters to try with them and the improvement was fantastic. So yes your 125s will work just fine. I am getting ready to bi amp them soon and expect them to only get better. One thing I can warn you of is that the speakers are not forgiving of a bad source or source material so you may find yourself looking to upgrade your album or cd collection.
Thanks for the feedback. Interesting comment about the super tweeters. Google got me up to speed. Are you going to get a pair for yourself?
Pulled the trigger. Time will tell!
