I'm restoring a ST70 and a pair of PAM-1 preamps.
I have them on the bench right now, and the ST70 is all dialed in and biased and seems to be working well.
The PAM-1 does work, but the filaments on the 12ax7's aren't lighting at all.
Measuring the voltage coming off the sel rectifier and going to the filaments, I see only 6.7VDC.
This should be doubled and closer to 12.6VDC right?
Does this mean one of the two diodes in the sel rectifier is shot?
Any help, confirmation, or suggestions to further test/prove this would be awesome.
Thank you
Thank you
