A couple of questions from the unwashed.
1. Firstly, has anyone else tried the 3D21WB Bendix, CBS or Tung-Sol or any other 3D21WB in lieu of a KT-88?
These are all from 1950-60s, NOS, the seller(s) say that with the adapter socket, they will drop right in for a KT88. If so, how do they bias and sound? Payoffs?
All other things being equal, which is the better-sounding OP Tube: The Kt-88/6550 series or the 6CA7/EL-34 series? And does it make sense to buy two ST-70s populated with two quads of the smaller (and earlier) EL-34s, or the ST-120 with a single quad of the bigger KT-88s?
A foursome of GEC Gold Lions fetches ~ $1,600
A good Mullard EL34 fetches about $50, so two quads of them come to $400.
Now a pair of ST-70 kits will cost quite a bit more $$ than a single ST-120 kit, for about the same power in either choice.
So for the first year or even two or much longer, when finally you replace your tubes, you'll be even. But the third time the ST-70s are re-tubed, they will beat the KT-88s price by $800 then and forever more, meaning that $800/year or whatever begins to add up against the ST-120.
So what sounds better? Four KT-88s or eight EL-34s?
