by aguaazul Sat Jun 13, 2020 6:33 am
dasa2131 wrote:Hello Aguaazul,
Thank you very much for the kind words - it's greatly appreciated. I've attached a few more pictures. For the outputs, I have two sets of speakon jacks: one for 4 ohm, one for 8 ohm speakers. Input jacks are just regular RCA jacks. Ideally, I'd have XLR jacks for balanced inputs on the back, but I'm not savy enough to figure out the balanced to unblanced circuitry.
Regarding what you said about moving the amp up to the top - I understand 100% where you're coming from. This thing really does put out a lot of heat. Not shown in the pictures, I actually have two 120mm fans blowing air across the transformers and tubes. They are mounted slightly above and behind the transformers. I have two internal 80mm fans that blow air into and out of the enclosure itself. When I run the amp, I always leave the rack door open. With all that said, I do like your idea of putting this amp near the top. I'll look into that - thank you for the suggestion!
What kind of amp/speakers are you running? Since you used to do live sound, are you using any pro-audio gear in your setup?
Thanks again,
Dave
Hey Dave,
Thanks for posting the photos. It's cool to see the I/O and routing. Nice use of the fans, if you used a deflector on the back of the rack, perhaps you could blow some exhaust air across the transformers & tubes, that would help cooling your ST-120, it's worth a try.
You have a very good looking build for sure!
We have a few speakers that we use for our dedicated 'Stereo' system.
We Bi-AMP a set of Bozak 1968 Symphony's using a VTA ST-120 for the Mids & Tweeters & a Carver A-220 Solid State Amp with high damping factor for the dual woofers per speaker. We use the Bozak N-106C Electronic Crossover.
Also in the mix is a set Klipsch Heresy I with fresh Crites Crossovers.
We also have a nice set of Dynaco A-25's, very natural sounding. They are in need of a crossover refresh.
I have a Pioneer D-23 - 4 - Way Active Crossover that we plan on using on the big Bozaks, the existing ST-120 (Mids) - Carver A-220 (Woofers) plus a fresh ST-120 for the 8 Speaker Tweeter Array (up to 12KHz) & a 1968 Dynaco ST-70 w the VTA driver board for a set of Silk-Domed Super-Tweeters that sit on top in dedicated enclosures for 12KHz & Up. I've been working on that setup for many moons and it's finally getting close!
No pro gear in the dedicated stereo setup. When we get the D-23 with 4 amplification systems in place, I'll use REW Room Acoustics Software to get the levels right.
Cheers,
Aguaazul
