I have a VTA PH16-X phono preamp that I absolutely love. I've upgraded the caps and rolled plenty of tubes and now have a favorite set that's I've used for about a year now. Every so often the right channel drops out on me though. If I lightly touch the output jack it will come back on. I've checked the cables multiple times with a multimeter and they are all in perfect working order. All the tubes have been checked as well. I've even opened up the unit and resoldered the connections to the jacks. That seemed to solve the issue for a few months but now it's starting to act up again. At this point I have the think that RCA jack is just bad or going completely bad so I figured I would look for an upgraded option since I'll have to replace it anyway.
Has anyone upgraded the RCA jacks on their unit, and if so what brand or part would you recommend? I've seen replacement jacks go for as low as $10 a piece and upwards over $200 a piece. I don't want to go with anything junk, but I'm not looking to put in jacks that would cost as much as the unit itself either.
I appreciate any feedback you can provide, or if any of you have run into this issue and know of another fix, I'm all ears, too.
Lou
