Three Mark II Amps
I've done a little research, in this forum and elsewhere, so I am aware that many recommend upgrading to the Mark III, and some recommend getting new circuit boards populated with metal film resistors. At this point, my main goal is to simply get each amp running, and have them produce sound that is equivalent to how they worked when new.
I have another friend who has a Hickok tube tester and a Variac. I have an isolation transformer. If he doesn't come through with the tester, I may be dead in the water, since even in Silicon Valley (100 miles to my north), there are no public tube testers anymore.
At this point my plan is to:
1. Test the tubes and replace both the missing tubes and any which test bad.
2. "Re-cap" each amp, although I need to read more to figure out whether I can just use modern caps from Mouser or Digikey, or whether I need to find something more exotic. I don't know yet where to get a replacement for the big can capacitor.
3. Power up, adjust the bias, and go home.
There appears to be a small selenium rectifier. I've replaced those before (in my old Wollensak T-1500 tape recorder), but figuring out the right value for the series resistor is a little hit or miss, and I'm not sure the work was necessary for my Wollensak, and it may not be for this either. Thus, I'm not planning to do anything with that at the moment.
I'll post back again as the work progresses.
