Hi all, I'm relatively new to tubes and need some advice on how to diagnose a problem with a Pas2. The left channel does not produce sound and one of the 12AX7 tubes on the PC5 glows much brighter than the other. I'm wondering if it could be related to the selenium rectifier/diodes; I did replace the electrolytic caps with the same values; new PC5 and PC6 boards; new rca kit; cleaned selector switch; checked all wiring/solder joints. The tubes tested in the lower range (waiting for new); rechecked all wiring/ solder joints; deoxit all pots (no scratchiness).
I'm wanting to test my voltages, but I'm a little hesitant because I've never done this before and thought I'd seek guidance from those of you that have.
Any and all guidance is truly appreciated. Thanks
