Basket
Topics | Replies | Author | Views | Last Posts | ||
![]() | Weird ST-70 distortion problem | 11 | gabe | 1303 | ![]() by j beede | |
![]() | Most horrible tune of the day | 21 | deepee99 | 1664 | ![]() by deepee99 | |
![]() | Need help determining correct bias adjustment | 15 | notboating | 1801 | ![]() by peterh | |
![]() | Help with Identification - ST70 | 10 | fastbulbous | 1345 | ![]() by fastbulbous | |
![]() | Montana Tube Meet | 8 | Guest | 1350 | ![]() by Bob Latino | |
![]() | Technical question concerning input grounds | 1 | gabe | 819 | ![]() by GP49 | |
![]() | True Bi-Amping | 5 | mazeeff | 1585 | ![]() by Bob Latino | |
![]() | SP14 looking for some help | 20 | Jeff V. | 2698 | ![]() by tiguan | |
![]() | ST-120 start up! 1, 2 | 29 | Maintarget | 3668 | ![]() by Maintarget | |
![]() | 240 volt power transformers now available from Dynakitparts for European Dynaco tube amp users ... | 4 | Bob Latino | 3181 | ![]() by peterh | |
![]() | Shuguang EL34 | 3 | mazeeff | 1069 | ![]() by peterh | |
![]() | New VTA ST-70 | 1 | bluerondo | 853 | ![]() by Bob Latino | |
![]() | VTA Amp For 85db Speakers | 7 | Jeff V. | 1104 | ![]() by Jeff V. | |
![]() | SP14 Thanks Roy! | 7 | Jeff V. | 1442 | ![]() by tiguan | |
![]() | New member with ST-120 questions | 11 | wgallupe | 1972 | ![]() by wgallupe | |
![]() | K40-Y Coupling Caps for the ST-70 VTA Upgraded Board | 2 | BNR_1 | 1133 | ![]() by BNR_1 | |
![]() | Newbie here - starting my Bob Latino M 125 Monoblock build 1, 2 | 32 | costerdock | 8471 | ![]() by kaner | |
![]() | Horn Speakers 1, 2 | 26 | Guest | 5791 | ![]() by TN Allen | |
![]() | Non Tech Newbie here ST70 help needed | 4 | raudio44 | 1051 | ![]() by raudio44 | |
![]() | Rock and Roll Combos and potted transformers | 7 | wildiowa | 1511 | ![]() by wildiowa | |
![]() | Vta St-70 Main Power Transformer Hum | 11 | islanddave | 2535 | ![]() by zx | |
![]() | my SP9/PH10 preamp build | 3 | Guest | 1360 | ![]() by Guest | |
![]() | octal vta problem | 12 | kost | 1526 | ![]() by tubes4hifi | |
![]() | Bad Recifier tube? | 11 | islanddave | 1085 | ![]() by Bob Latino | |
![]() | another VTA ST70 chassis variation | 12 | Guest | 3972 | ![]() by tubes4hifi | |
![]() | Need serious help | 11 | 5/35 | 1053 | ![]() by audiobill | |
![]() | Bob's M125 and my spiral bass horns | 4 | carpenter | 1317 | ![]() by carpenter | |
![]() | FM-3 Rebuild | 10 | Maintarget | 4066 | ![]() by Dynalover | |
![]() | What gauge wire in VTA preamps? | 3 | AudioMartin | 734 | ![]() by Guest | |
![]() | cap gone bad? | 4 | colin86325 | 788 | ![]() by Dynalover | |
![]() | Why output transformers are necessary on a tube amp ? | 8 | Bob Latino | 2254 | ![]() by Bob Latino | |
![]() | What does a scratch built VTA ST-70 sound like when it clips? 1, 2 | 49 | Downhome Upstate | 3679 | ![]() by Guest | |
![]() | Amplifier power requirement calculator | 2 | audiobill | 854 | ![]() by tubes4hifi | |
![]() | My VERY first tube amp. 1, 2 | 37 | Tevian | 3911 | ![]() by tubes4hifi | |
![]() | cryo tubes | 19 | Guest | 1964 | ![]() by Guest | |
![]() | What transformer should I replace for running 6550 tubes | 6 | EugeneHiFi | 1629 | ![]() by EugeneHiFi | |
![]() | Rebuild of some really old MKIV's 1, 2 | 35 | MarcVBelgium | 4844 | ![]() by DynakitParts | |
![]() | ST-70 VTA left channel driver problem | 7 | w_barton | 1265 | ![]() by w_barton | |
![]() | VTA amplifier gain | 5 | audiobill | 1237 | ![]() by audiobill | |
![]() | VTA M-125 vs. Conrad Johnson LP 125M | 1 | audiobill | 1183 | ![]() by deepee99 | |
![]() | Microphonic Driver Tube | 4 | kaner | 941 | ![]() by sKiZo | |
![]() | Superior variacs on eBay | 1 | Gregg R. | 800 | ![]() by zx | |
![]() | ST-70 age and care | 3 | chrisj | 1089 | ![]() by Guest | |
![]() | Running two ST-70's from same source | 8 | mazeeff | 1129 | ![]() by zx | |
![]() | Replacement of voltage pot of Eico 950B RC bridge checker | 0 | hifitracer | 772 | ![]() by hifitracer | |
![]() | Power Transformer Tempeture Question | 19 | tkemmett | 2076 | ![]() by corndog71 | |
![]() | ST-70 Series 2 refurbishment | 10 | offanonone | 1788 | ![]() by Dogstar | |
![]() | VTA ST120 Step by Step Diagnostic Checklist? | 9 | tkemmett | 2432 | ![]() by GP49 | |
![]() | ST-120 / EL-34 and or 7591 ? | 3 | scottlowe | 1031 | ![]() by tubes4hifi | |
![]() | SP14 Output Capacitor Values | 3 | AudioMartin | 1384 | ![]() by AudioMartin |
Users browsing this forum: 0 Registered, 0 Hidden and 4 Guests
Registered Users: None
