Let me start by saying Hello to everyone since this is my first post. I've been in the hobby for about 10 years, but only recently chasing Dynaco gear.
On to the question, I recently purchased a set of 4 transformers that were supposedly used in a pair of MKIII's. The all important outputs appear to be original with the woven insulation on the leads, however the power transformers appear to be a more modern replacement of unknown make. The size, shape, and windings all match the common P782 replacements with the exception of the bias tap missing. There is no stamping or stickers/labels anywhere, and I pulled the covers to see if they were maybe painted and they looked as though they were grey before. The covers are shaped the same as the originals. I was told that the gentleman who owned these was into building his own amps 20-30 years ago, so these are likely from around that time.
I apologize for having no photos to assist in the ID, but because I'm so new I cannot post any pics yet. I was hoping that the old heads of this forum may have known of a replacement that was once offered without the bias tap.
In case these numbers help, here are voltages from my test,
Primary
BLK-BLK - 122vac applied from wall
Secondary
YEL-YEL - 5.5vac
RED-RED/YEL-RED - 440-0-440vac
GR-GR/YEL-GR - 3.6-0-3.6vac
Thanks in advance for any information you guys can help me gather about these.
Nick
Primary
Secondary
YEL-YEL - 5.5vac
Nick
