Here's my midnight analysis of the this topic:
This is a link to document, Hammond Grand 100, part 3, pages 29-31, that I use as the reference for my discussion:
http://theatreorgans.com/hammond/faq/g100/Hammond%20Grand%20100%20service%20manual%20Part%203%20pages%2029-31%20(amplifiers).pdfIt is clear that the Hammond AO-59 is a custom version of the Dynaco MKIII and the Hammond AO-58 is a custom version of the Dynaco ST70. Now weather Dynaco manufactured
the amps themselves or contracted out to 3rd party manufactures is as far as I can see is unknown, very common practice even back then.
I am confident that the Hammond procurement dept and the service departments had the Dynaco Amps as authorized substitutes for the Hammond Versions.
The Power and Output Transformers are variants of the original
Dynaco versions in that the output transformers have a single 8 ohm output and the power
transformer has lower voltage bias taps. I am of mind that using a bias balance pot instead of a bias level pot was a intentional design choice.
Looking at the AO-59 Schematic, the negative bias voltage of -54v is listed. (If this had been a Dynaco transformer it would have been -77v).
If you calculate the equivalent resistance of all of the bias resistors and then the voltage at the KT88 grids will be -43.7v, about right for a 70ma current bias per tube.
I don't know why this design decision was made except it could be the company's "way of doing things". It could be they would not have to buy matched pairs of tubes and
as long as the tubes meet the specs and the ruggable tubes back then they would be OK.
I believe that there is a cathode resistor and the schematic is mistaken because if you look at the AO-58 schematic a 10 ohm resistor is there.
On a side note, since the AO-59 does not use a pwb assembly for the driver circuit, i would love to see a picture of the inside of chassis
to see if they used a turret/eyelet board and/or terminal strips in the assembly. I have always liked the looks of a well crafted terminal strip assembly.
