    Using an MC Cartridge
    Post by Tube Nube on Thu Apr 02, 2009 12:21 pm
    Greetings, once again, to this learned and helpful community.
    I have another question for anyone with an opinion.
    I' thinking to up grade my phono cartridge to a low output moving coil, but to do this, one needs to step up the signal so the moving magnet input on the pre amp can deal with it.
    I'm reading a bit about Step Up transformers, which can be difficult to mate to the rest of the equipment and, I understand, can act as a filter, cutting the frequency response down. (I think I have that right)
    The other major option is a so-called "head amplifier", to actively amplify the signal.
    I'd sure appreciate recommendations, and I'd prefer to go with a DIY kit, if there are any.
    Brenton
    Re: Using an MC Cartridge
    Post by Bob Latino on Thu Apr 02, 2009 2:29 pm
    Tube Nube wrote:Greetings, once again, to this learned and helpful community.
    Brenton
    Brenton,
    Do you have any phono stage on your preamp now or is it just a line stage ?
    Post by Tube Nube on Thu Apr 02, 2009 3:39 pm
    Hi Bob,
    I have the Transcendent Phono Stage running into the Transcendent Pre amp.
    Post by Bob Latino on Thu Apr 02, 2009 4:29 pm
    Brenton.
    The Transcendent phono stage can be used with moving coil cartridges but may not have enough gain for very low output moving coil cartridges. IMHO you should probably stick with a medium or high output MC cartridge. Some phono cartridges can get pretty expensive and some step-up transformers can be expensive also.
    If you do want to try a low output MC cartridge I know that Jensen makes some reasonably priced step-up transformers for low output moving coil cartridges. Check the link below.
    http://www.jensen-transformers.com/mc.html
    Post by Tube Nube on Thu Apr 02, 2009 6:57 pm
    Hi Bob,
    Thanks for this perspective, and for the Jensen Link!
    JunkyJan
    Something else you might want to try...
    Post by JunkyJan on Fri May 01, 2009 4:30 pm
    Hi Tube Nube
    (I have been away for a while - job related - again!)
    There is a a high-output MC cartridge that I can whole-heartidly and without any qualms recommend (and therefore solve the step-up transformer problem):
    The Denon DL-160 (and it is relatively CHEAP!)
    It is a mind-blowing cartridge, seems to have quite the fan group - and puts some other expensive higher-end MC cartridges to shame. I bought one from the Needle Doctor (IIRC) as a "cheapie" thinking that it will serve me until I can get around to buying a high-end MC (I'm kinda broke at the moment - kids at college etc), but frankly I am totally happy with it.
    Excellent dynamics, stereo imaging, 3D imaging, works for Classical, Jazz, Rock...
    -- JunkyJan
      Current date/time is Wed May 16, 2012 7:30 pm
