+6
Soundbrigade
thinker1920
turbodan
10 posters
    Board layouts for the PC-5 line stage and PC-6 phono board on the PAS preamps - photos ...
    oldsmobuick
    Board layouts for the PC-5 line stage and PC-6 phono board on the PAS preamps - photos ... - Page 2 Empty Re: Board layouts for the PC-5 line stage and PC-6 phono board on the PAS preamps - photos ...
    Post by oldsmobuick Thu Mar 19, 2015 8:51 pm
    Question: my PC6 board from T4HF has the .047 caps as 0.10 caps (unless I am remembering wrong?). Is this by design? Thanks!
    Post by Roy Mottram Thu Mar 19, 2015 9:39 pm
    yes, the board works the same with the larger capacitor value
    oldsmobuick
    Post by oldsmobuick Thu Mar 19, 2015 9:41 pm
    Thanks Roy! Really enjoying the boards!
    -Nick
    oldsmobuick
    Post by oldsmobuick Wed Mar 25, 2015 3:59 pm
    One more question, on the layout above there is a 4M7 resistor on PC6. Does that come as a 2M resistor these days? Or maybe I didn't swap the 4M7 back in after I tried the Curcio RIAA mod. I have a 2M there but wanted to go back to a stock PC6 board circuit.
    Post by Roy Mottram Fri Apr 03, 2015 10:57 pm
    it's hard to find a 4.7M resistor these days, and the 2.2M actually gives a slightly better RIAA EQ for the phono section.
    breading
    Post by breading Fri Oct 08, 2021 6:21 pm
    roy,
    In your post from 2015 regarding the layout for the PAS3 PC-6 board you state that 2 100K resistors should be changed to 95.3K. There are actually 4 100K resistors on the board. Which are to be changed?
    Bruce
    Post by Roy Mottram Fri Oct 08, 2021 8:50 pm
    Bruce,
    if you look at post 2 in this thread the parts list shows which one should be 95.3K for better phono EQ
      Current date/time is Wed May 08, 2024 10:49 am
