I have a Technics SL1100. It's in very good condition. I bought it from a local seller when I lived in Concinnati. The cover had one very deep scratch until I spent hours buffing out with polishing compound until there no evidence of a ever having a scratch. I do not have the optional probe for it which is plugged into the AC outlet that is in the round pocket where the 45 RPM adapter is stored if you don't have a probe. I hunted high and low on the internet for a strobe and the ones I found on eBay are going for as much as I paid for the turntable. It has the original tonearm with the rectangular shaped counterweight. The only thing I've done to it other than polish out the cover scratch is clean it thoroughly with lens cleaner and Q-tips. It performs flawlessly.
The SL1100 came with a Shure V15 Type III cartridge. I replaced the stylus due to accidentally breaking off the cantilever shaft. I think I got the exact replacement for it.
I also have a Technics SL1200MkII that is in very good condition. It was professionally refurbished by the previous owner and it looks and performs perfectly other than two minor scratches on the top surface. It came with an aftermarket cover that feels more like plastic than the thicker acrylic that's on the SL1100. It also came with a heavy duty round steel plate that is designed to dampen any resonance the turntable can pick up from the sound chomping from the speakers. I'll find the plate manufacturer through Google. It also came with a felt mat to use with the plate but I replaced that with a new rubber platter mat.
The seller also threw in a brand new Shure M97xe (?) cartridge. I purchased a Denon DL110 cartridge a few weeks before I got the SL1200 and I decided to install it to the SL1200 tonearm's head shell.
And the last turntable is a Thorens TD-160 with the original tonearm. It too has been refurbished. Additionally it had a custom plinth made by a custom plinth maker out of a dense material that is supposed help eliminate any vibration. I think the material is called wood. I'm going to search the Internet to see if I can find the manufacturer of the plinth. I got it at Axpona a few years ago from the owner of SilNote Audio, the cable company.
I installed the Shure M97xe cartridge on the Thorens turntable's tonearm.
All three turntables sound good. Because they are in three different rooms on three systems I cannot compare them. The only issue I have is that because of the Thorens TD-160's suspension system it sometimes skips when I'm trying to rush to the listening chair. and from what I've read this is not unique to my turntable. If I keep I'm going to have to get or fabricate a wall mounted shelf to isolate the turntable from the floor.
I just had granite countertops installed in my kitchen and I have a leftover slab from the sink cutout that may be a perfect shelf for the Thorens.
I'm going to sell one of my sound systems. The bedroom system will be dedicated to CD's or a tuner or perhaps a music server. The family room system will be devoted to Vinyl LP's or CD's and because of that I need only one turntable.
Which would you suggest I keep?
