Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4100 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 856 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1367 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
Most horrible tune of the day | 19 | deepee99 | 1932 | Wed Oct 01, 2014 4:01 pm by deepee99 | ||
Need help determining correct bias adjustment | 15 | notboating | 2175 | Mon Sep 29, 2014 5:10 pm by peterh | ||
Help with Identification - ST70 | 10 | fastbulbous | 1498 | Sun Sep 28, 2014 9:51 pm by fastbulbous | ||
Montana Tube Meet | 8 | Guest | 1466 | Sun Sep 28, 2014 8:22 am by Bob Latino | ||
Technical question concerning input grounds | 1 | gabe | 983 | Fri Sep 26, 2014 1:19 pm by GP49 | ||
True Bi-Amping | 5 | mazeeff | 2187 | Fri Sep 26, 2014 12:06 pm by Bob Latino | ||
SP14 looking for some help | 20 | Jeff V. | 2897 | Fri Sep 26, 2014 4:19 am by tiguan | ||
ST-120 start up! 1, 2 | 29 | Maintarget | 3922 | Thu Sep 25, 2014 11:02 pm by Maintarget | ||
240 volt power transformers now available from Dynakitparts for European Dynaco tube amp users ... | 4 | Bob Latino | 3682 | Thu Sep 25, 2014 5:12 pm by peterh | ||
Shuguang EL34 | 3 | mazeeff | 1285 | Wed Sep 24, 2014 4:31 pm by peterh | ||
New VTA ST-70 | 1 | bluerondo | 943 | Sun Sep 21, 2014 8:44 pm by Bob Latino | ||
VTA Amp For 85db Speakers | 7 | Jeff V. | 1299 | Sun Sep 21, 2014 3:29 pm by Jeff V. | ||
SP14 Thanks Roy! | 7 | Jeff V. | 1616 | Sun Sep 21, 2014 2:48 am by tiguan | ||
New member with ST-120 questions | 11 | wgallupe | 2114 | Sat Sep 20, 2014 2:48 pm by wgallupe | ||
K40-Y Coupling Caps for the ST-70 VTA Upgraded Board | 2 | BNR_1 | 1406 | Thu Sep 18, 2014 6:36 pm by BNR_1 | ||
Newbie here - starting my Bob Latino M 125 Monoblock build 1, 2 | 32 | Guest | 9146 | Wed Sep 17, 2014 9:22 am by kaner | ||
Horn Speakers 1, 2 | 26 | Guest | 6626 | Tue Sep 16, 2014 6:35 pm by TN Allen | ||
Non Tech Newbie here ST70 help needed | 4 | raudio44 | 1223 | Mon Sep 15, 2014 8:09 pm by raudio44 | ||
Rock and Roll Combos and potted transformers | 7 | wildiowa | 1843 | Mon Sep 15, 2014 5:32 pm by wildiowa | ||
Vta St-70 Main Power Transformer Hum | 11 | islanddave | 3878 | Mon Sep 15, 2014 12:04 pm by zx | ||
my SP9/PH10 preamp build | 3 | Guest | 1524 | Sun Sep 14, 2014 4:55 pm by Guest | ||
octal vta problem | 12 | kost | 1716 | Sun Sep 14, 2014 2:24 am by Roy Mottram | ||
Bad Recifier tube? | 11 | islanddave | 1226 | Fri Sep 12, 2014 6:07 pm by Bob Latino | ||
Need serious help | 11 | 5/35 | 1262 | Tue Sep 09, 2014 4:34 pm by audiobill | ||
Bob's M125 and my spiral bass horns | 4 | carpenter | 1467 | Sun Sep 07, 2014 11:01 pm by carpenter | ||
FM-3 Rebuild | 10 | Maintarget | 6007 | Sun Sep 07, 2014 7:44 pm by Dynalover | ||
What gauge wire in VTA preamps? | 3 | AudioMartin | 895 | Sun Sep 07, 2014 4:04 pm by Guest | ||
cap gone bad? | 4 | colin86325 | 983 | Sun Sep 07, 2014 1:41 pm by Dynalover | ||
Why output transformers are necessary on a tube amp ? | 8 | Bob Latino | 3145 | Fri Sep 05, 2014 1:25 pm by Bob Latino | ||
What does a scratch built VTA ST-70 sound like when it clips? 1, 2 | 49 | Downhome Upstate | 4029 | Wed Sep 03, 2014 9:14 pm by Guest | ||
Amplifier power requirement calculator | 2 | audiobill | 974 | Tue Sep 02, 2014 12:41 am by Roy Mottram | ||
My VERY first tube amp. 1, 2 | 37 | Tevian | 4278 | Tue Sep 02, 2014 12:36 am by Roy Mottram | ||
cryo tubes | 19 | Guest | 2270 | Thu Aug 28, 2014 12:46 pm by Guest | ||
What transformer should I replace for running 6550 tubes | 6 | EugeneHiFi | 2059 | Mon Aug 25, 2014 1:35 pm by EugeneHiFi | ||
Rebuild of some really old MKIV's 1, 2 | 35 | MarcVBelgium | 6079 | Fri Aug 22, 2014 6:43 pm by DynakitParts | ||
ST-70 VTA left channel driver problem | 7 | w_barton | 1630 | Fri Aug 22, 2014 2:40 am by w_barton | ||
VTA amplifier gain | 5 | audiobill | 1553 | Wed Aug 20, 2014 1:43 pm by audiobill | ||
VTA M-125 vs. Conrad Johnson LP 125M | 1 | audiobill | 1301 | Wed Aug 20, 2014 11:48 am by deepee99 | ||
Microphonic Driver Tube | 4 | kaner | 1099 | Tue Aug 19, 2014 3:19 pm by sKiZo | ||
Superior variacs on eBay | 1 | Gregg R. | 921 | Mon Aug 18, 2014 9:45 am by zx | ||
ST-70 age and care | 3 | chrisj | 1457 | Sat Aug 16, 2014 10:21 am by Guest | ||
Running two ST-70's from same source | 8 | mazeeff | 1288 | Sun Aug 10, 2014 8:52 am by zx | ||
Replacement of voltage pot of Eico 950B RC bridge checker | 0 | hifitracer | 962 | Sat Aug 09, 2014 7:45 pm by hifitracer | ||
Power Transformer Tempeture Question | 19 | tkemmett | 2421 | Fri Aug 08, 2014 4:17 pm by corndog71 | ||
ST-70 Series 2 refurbishment | 10 | offanonone | 2303 | Tue Aug 05, 2014 8:59 pm by Dogstar | ||
VTA ST120 Step by Step Diagnostic Checklist? | 9 | tkemmett | 3966 | Tue Aug 05, 2014 10:44 am by GP49 | ||
ST-120 / EL-34 and or 7591 ? | 3 | scottlowe | 1182 | Sun Aug 03, 2014 10:51 pm by Roy Mottram | ||
SP14 Output Capacitor Values | 3 | AudioMartin | 1706 | Sun Aug 03, 2014 8:34 pm by AudioMartin | ||
History of the VTA-120 | 3 | mazeeff | 1117 | Sat Aug 02, 2014 9:12 pm by sKiZo | ||
Turntable questions | 8 | Dale Stevens | 1423 | Fri Aug 01, 2014 10:51 pm by deepee99 |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 3 Guests
Registered Users: None
