Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4148 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 879 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1378 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
SP 14 Built | 15 | tiguan | 2493 | Mon Nov 24, 2014 8:09 am by tiguan | ||
Howto cut 5V from the mains line | 4 | peterh | 1462 | Mon Nov 24, 2014 4:44 am by Pillo69 | ||
Remote Volume Control in SP9 | 8 | TMadden | 1280 | Sun Nov 23, 2014 9:18 am by TMadden | ||
MK III bias recommendation with Electro Harmonix KT88's | 4 | gflash | 2733 | Sat Nov 22, 2014 4:40 pm by sKiZo | ||
M-65 Mono Blocks | 5 | TMadden | 1118 | Sat Nov 22, 2014 2:41 pm by deepee99 | ||
VTA ST70 ΚΤ120 tubes | 8 | kost | 2584 | Thu Nov 20, 2014 11:13 pm by bluerondo | ||
Going woodie. MontanaWay's modified M-125s, the Big Boppers 1, 2 | 29 | deepee99 | 3603 | Wed Nov 19, 2014 2:51 pm by deepee99 | ||
The Ponoplayer - a high end type music source - coming early 2015 ... | 13 | Bob Latino | 1398 | Mon Nov 17, 2014 5:06 pm by sKiZo | ||
STA 35 Integrated | 5 | david kurek | 1353 | Fri Nov 14, 2014 5:53 pm by zx | ||
Will be getting my ST120 soon! | 16 | Jerryfan | 2893 | Fri Nov 14, 2014 1:13 pm by Jerryfan | ||
Pair of Dynaco Mark VIs .... Worth a try? | 9 | cgregory4 | 2164 | Mon Nov 10, 2014 1:27 pm by Roy Mottram | ||
Diode on bias supply caps | 8 | colin86325 | 1557 | Mon Nov 10, 2014 11:17 am by anbitet66 | ||
Not really audio related, but maybe someone here has some mechanical aptitude | 5 | Elrick | 1286 | Wed Nov 05, 2014 8:43 pm by Elrick | ||
MK3 build photos | 5 | Roy Mottram | 1957 | Tue Nov 04, 2014 7:22 pm by Dingojazz | ||
Custom Base For VTA ST-120 | 21 | Hoffsgarage | 4696 | Tue Nov 04, 2014 11:10 am by bluerondo | ||
Remote control for preamp from china | 8 | peterh | 1627 | Sat Nov 01, 2014 5:20 pm by peterh | ||
SP14 Russian Teflons | 3 | Jeff V. | 1429 | Sat Nov 01, 2014 4:13 pm by Bob Latino | ||
matching triodes | 13 | Guest | 1319 | Fri Oct 31, 2014 3:02 pm by Jim McShane | ||
ST120 - Noise in one channel after valve red plated | 9 | Alan-14 | 2090 | Wed Oct 29, 2014 4:25 pm by Bob Latino | ||
Any danger changing feedback line from 16 ohm to 8 ohm tap? | 13 | n3ikq | 10583 | Wed Oct 29, 2014 10:45 am by arledgsc | ||
bias pot query | 6 | Guest | 1855 | Mon Oct 27, 2014 6:34 pm by sKiZo | ||
Tube swapping on the VTA driver board | 11 | mazeeff | 1617 | Sun Oct 26, 2014 1:55 pm by eickmewg | ||
Basic Audio Question | 9 | harpy | 1365 | Sun Oct 26, 2014 1:49 pm by harpy | ||
interesting Weber Copper Top issue | 20 | Guest | 3233 | Fri Oct 24, 2014 12:38 pm by deepee99 | ||
Starting a rebuild (ST-70) | 2 | ray.moats | 1024 | Fri Oct 24, 2014 11:08 am by ray.moats | ||
Tube Pre-amp Tech Wanted | 6 | WntrMute2 | 997 | Wed Oct 22, 2014 10:18 am by corndog71 | ||
Need help/suggestions on this ST70. | 14 | poconoman | 1398 | Tue Oct 21, 2014 10:28 am by poconoman | ||
ST70 input options to replace stereo/mono switch | 3 | n3ikq | 1395 | Mon Oct 20, 2014 5:04 pm by n3ikq | ||
New ST-70 has an odor | 17 | Jeff V. | 1920 | Mon Oct 20, 2014 12:41 am by Roy Mottram | ||
Anyone use Shuguang Treasures or Psvanes in their VTA ST-70? | 10 | deluxmon | 2189 | Sun Oct 19, 2014 5:40 pm by deepee99 | ||
Picture of PAS-3 connections | 2 | peterh | 955 | Sat Oct 18, 2014 4:43 pm by peterh | ||
new meter choices | 6 | icky | 1547 | Fri Oct 17, 2014 1:39 pm by Guest | ||
ST70 bias pots question | 9 | n3ikq | 1670 | Thu Oct 16, 2014 4:53 pm by zx | ||
Passive VU meter circuit | 5 | Dale Stevens | 3951 | Tue Oct 14, 2014 5:07 pm by Dale Stevens | ||
dynaco parts in europe | 14 | peterh | 1725 | Mon Oct 13, 2014 5:52 pm by Pillo69 | ||
my version of the ST120 1, 2 | 26 | Guest | 2489 | Mon Oct 13, 2014 1:52 pm by deepee99 | ||
ST70 eyelet cap location on PC-3. | 0 | poconoman | 749 | Sun Oct 12, 2014 11:17 pm by poconoman | ||
XRECODE SOFTWARE | 0 | baddog1946 | 805 | Sun Oct 12, 2014 12:40 pm by baddog1946 | ||
ST70 coupling caps eyelet location on PC-3? | 1 | poconoman | 925 | Sat Oct 11, 2014 9:06 pm by Bob Latino | ||
ST-70 MONO, STRAPPED. Old question, asked again-- looking for new answer | 8 | Nycjimp | 1235 | Sat Oct 11, 2014 2:31 pm by Aljaheejus | ||
Mark 3 Rectifier & Mono Preamp | 7 | TN Allen | 1005 | Fri Oct 10, 2014 12:44 am by stewdan | ||
ST120 PROBLEM | 11 | pigface | 2046 | Thu Oct 09, 2014 7:20 pm by pigface | ||
Standby switch | 3 | audiobill | 975 | Thu Oct 09, 2014 1:22 pm by deepee99 | ||
Room treatment suggestions, anyone? | 16 | deepee99 | 1533 | Tue Oct 07, 2014 11:34 pm by deepee99 | ||
Proper use of the variac for tube equipment on startup? | 3 | eickmewg | 1466 | Tue Oct 07, 2014 12:19 pm by sKiZo | ||
NFB Connection Point | 2 | mazeeff | 935 | Tue Oct 07, 2014 10:57 am by zx | ||
Factory Wired | 2 | harpy | 1187 | Mon Oct 06, 2014 10:03 pm by j beede | ||
VTA ST-70 enclosure | 2 | bluerondo | 1005 | Sun Oct 05, 2014 3:14 pm by DynakitParts | ||
Newbie St-120 Build | 6 | Digdug | 1274 | Fri Oct 03, 2014 5:51 pm by Digdug | ||
Dynaco ST70 mono question. | 3 | poconoman | 901 | Fri Oct 03, 2014 9:08 am by poconoman |
Sort
Users browsing this forum: 1 Registered, 0 Hidden and 1 Guest
Registered Users: peterh
