by sKiZo Sat Jul 06, 2013 4:59 pm
Been some progress here ... tried updating earlier, but couldn't find the thread.
Got the case together and the iron mounted ...
Turned out pretty decent I think. I added some dense foam strips to the dadoes that trap the top plate in the sides, then just used pocket screws to draw it together. Right tight, vibration proof, and feels solid. I'm leaving the iron bare. Once I cleaned off all the stack glue and polished them up, they looked good. The bells took on a nice gray metal tone. A couple coats of Never Dull metal polish should keep them from rusting or changing color.
I did have a dOH! moment on the back panel.
I plan to use banana plugs with the speaker 5way jacks, and plenty of room for robust RCA interconnects. Couldn't get the fuse out though. dOH! Easy fix ... I just dremeled a slot into the cap - insert dime, twist, problem solved.
Here's the internal layout. Amazing what a couple inches of height and depth can do. I kept looking about for stuff I forgot to put in.
I just cut straps for the caps out of roofing tin and used available mounting screws. Only thing missing is a small power converter I got coming to provide 24v for the light on the power switch. Pure bling there. The meters won't get mounted till the job's almost done to minimize movement shock. No sense bouncing them around any more than I have to.
One concern ... the chokes are mounted to the wooden sides. Do they need to ground thru the mounting tabs? No big deal if I have to run a couple straps to the main chassis plate.
All in all ... the hard part's done. Time to get out the soldering gun and see if I can blow it up!
