Meter circuit v3.2 (beta)
Didn't like the mV meters ... they're made to mount behind the panel and aren't going to work unless I add an extra bezel and space that out another half inch up from the main panel. Yuk. So ... back to one of the original ideas of using the original mA meters, but converting them to mV ...
Snip!
Easy so far ... the clear covers pop right off and two screws to remove the scale. Just bent the shunt resistor lead out of the way and that's the only internal mod. I went with a VR on the plus terminal instead to adjust the meter to match the circuit. They're log scale, and I'll have them turned all the way down prior to powering up the first time.
Had some nice 50k laying about - those might be a bit twitchy to adjust, but no worries about not having enough range to work with. Mounting them was simple enough - soldered them in, then hot glued to the back of the meter is all.
NOTE >> There IS another resistor already in place on the hot lead ... 0.75 ohm ... I left that in place for now. The external VR should still be able to match the meter, unless I end up with a negative value. Those HopSun meters actually have quite a bit of room to work in, so be easy enough to remove if it's an issue.
That's as far as I got last night - it was getting late, and I want to fire it up without the meter wiring in place just to make sure things are good as is. All that's left then is to wire them into the amp. The amp's been rewired to the original schematic otherwise. The meter feeds will just be piggybacked onto the same test points I use for the VOM readings and be selectable with the SPDT mini switches which now have a center off position.
Short version ... I'm pretty much back where I was, only with the modded meters w/VR and the center off switches ...
Anyway ... that will leave me with this as the final(?) circuit ...
