I added 1" to both the depth and width and 1 1/4" to the height so not a radical difference from stock enclosure just a little more room for relocating the quad cap and rerouting power switch wiring to front and input to rear.
Another option for achieving a smooth large radius is to bend metal over a pipe of the desired radius the option for radius size are almost limitless.
Thanks for the link to front panel express interesting may try in the future as my time is very limited (Dam job always gets in the way LOL)
I ordered the same single pin bias sockets used for the M 125 mono blocks and plan to install flush under top panel, screw driver access will be through a small hole.
I'm really excited to move on the the next phase of the project building of the enclosure.
Thanks for the heads up on the up grade chokes and the grounded power cord
