Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4100 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 856 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1367 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
SP14 and PH16 Preamps Voltage Gain in dB ? | 4 | mijohn | 1939 | Tue Jun 16, 2015 11:07 pm by mijohn | ||
Recapping a Conn organ amp | 8 | rfbro | 1184 | Tue Jun 16, 2015 7:14 pm by wildiowa | ||
Hello im a new Forum person. | 2 | zipper | 747 | Tue Jun 16, 2015 6:53 pm by Roy Mottram | ||
PAD ST70 and opamp buffer board by Purist Audio Design | 2 | JohnInICT | 1341 | Sat Jun 13, 2015 8:17 am by JohnInICT | ||
ST70 upgrade to VTA70 tube information needed | 5 | McGar | 1356 | Thu Jun 11, 2015 9:30 am by eickmewg | ||
PH-16 Phono Preamp and Dynavector 20X2 cartridge | 0 | mijohn | 811 | Thu Jun 11, 2015 7:22 am by mijohn | ||
VTA 70 bias question | 3 | tubenutr | 1089 | Wed Jun 10, 2015 4:13 pm by Bob Latino | ||
Upgrading a stock st70 driver board | 3 | cheehpogi | 1069 | Wed Jun 10, 2015 12:01 pm by Roy Mottram | ||
st70 current draw | 4 | corporalspiffy | 1897 | Tue Jun 09, 2015 6:11 pm by Roy Mottram | ||
Low PH 10 phono volume in PAS 2 | 8 | Dingojazz | 1343 | Mon Jun 08, 2015 11:34 am by Dingojazz | ||
cooler running power transformer with change in driver tubes ? | 2 | tajanes | 1036 | Sun Jun 07, 2015 4:06 pm by tajanes | ||
Toob tips for newbies, and I'm one, too | 13 | deepee99 | 1285 | Sun Jun 07, 2015 9:51 am by deepee99 | ||
Setting Bias on ST70: issues I can't find elsewhere on board. | 4 | DC92 | 1215 | Sat Jun 06, 2015 2:42 pm by DC92 | ||
How Well Can You Hear Audio Quality? Check this out on the NPR web site | 10 | Bob Latino | 1251 | Fri Jun 05, 2015 5:10 pm by zx | ||
Interconnect cables. | 20 | Frank111 | 1882 | Fri Jun 05, 2015 11:40 am by corndog71 | ||
What happened with grooveshark | 7 | baddog1946 | 999 | Thu Jun 04, 2015 12:31 pm by GP49 | ||
chassis stand | 3 | neali | 1385 | Tue Jun 02, 2015 2:48 pm by sKiZo | ||
Everything working great, then... | 10 | SnugDynaco | 1222 | Mon Jun 01, 2015 12:40 pm by Bob Latino | ||
No bias on the 6550 tube Dynaco ST 70 | 11 | EugeneHiFi | 2343 | Sun May 31, 2015 10:23 am by deepee99 | ||
Grooveshark - music download site - shut down yet back ? | 15 | Bob Latino | 1477 | Sun May 31, 2015 8:37 am by Bob Latino | ||
'Special' input on Dyna Pas3 preamp | 3 | hrudu90 | 2280 | Sat May 30, 2015 5:41 pm by GP49 | ||
Separate Rectification for VTA Board and Output | 0 | kblsnbts | 804 | Sat May 30, 2015 9:31 am by kblsnbts | ||
The Hammond AO-58-1 > A hard wired Dynaco ST-70 clone from the 1960's | 9 | Bob Latino | 4780 | Sat May 30, 2015 6:27 am by singNdrink | ||
The Nobis Cantabile - An ST-70 type "hybrid" amp from the 1990's - photos .. | 8 | Bob Latino | 5995 | Fri May 29, 2015 1:39 am by Gregg R. | ||
Heat/cool cycle in one tube in my ST-120 | 4 | antipodean | 754 | Thu May 28, 2015 9:19 pm by sKiZo | ||
Speaker crossover recap | 0 | Dale Stevens | 698 | Thu May 28, 2015 6:34 pm by Dale Stevens | ||
Transformer layout question | 3 | 1bigpig | 1069 | Thu May 28, 2015 5:51 pm by corndog71 | ||
Dynaco mkiv problem | 4 | Trilogy 901 | 840 | Wed May 27, 2015 11:56 am by Trilogy 901 | ||
Digital buzzing sound, both channels, you can set your watch by it 1, 2 | 44 | deepee99 | 3428 | Tue May 26, 2015 9:05 am by pmarcin | ||
Alan Blumlein and the invention of "stereo" | 0 | Bob Latino | 673 | Mon May 25, 2015 6:09 pm by Bob Latino | ||
VTA hour meter | 6 | Dale Stevens | 1197 | Fri May 22, 2015 10:57 pm by sKiZo | ||
capacitors (polyprop) installed backwards? | 12 | corporalspiffy | 2199 | Wed May 20, 2015 7:02 pm by deepee99 | ||
$$499,999,99 on Ebay | 7 | Dale Stevens | 1200 | Wed May 20, 2015 5:45 am by mark four | ||
2015 Midwest Audiofest | 0 | Dale Stevens | 780 | Mon May 18, 2015 3:28 pm by Dale Stevens | ||
4 ohm speaker | 3 | rfbro | 1320 | Sun May 17, 2015 4:35 pm by Bob Latino | ||
el34 st70 voltages | 4 | corporalspiffy | 1582 | Sun May 17, 2015 7:09 am by corporalspiffy | ||
Blend Switch - Yes or NO? | 10 | aguaazul | 1523 | Thu May 14, 2015 12:54 pm by aguaazul | ||
the most ridiculously priced cables so far | 20 | baddog1946 | 2032 | Thu May 14, 2015 11:34 am by j4570 | ||
listening room improvement site | 5 | baddog1946 | 1155 | Sat May 09, 2015 6:27 pm by sKiZo | ||
PAS 3X Phono out using tape out to NAD C326BEE line level in | 5 | 3XTASK | 1459 | Fri May 08, 2015 1:38 pm by 3XTASK | ||
your listening room is a system component | 5 | Roy Mottram | 1284 | Fri May 08, 2015 1:21 am by sKiZo | ||
Can anyone identify this Dynaco ST-70 PCB? | 2 | MikeTorello | 952 | Thu May 07, 2015 6:02 pm by MikeTorello | ||
Flash under KT-120 | 15 | Frank111 | 1605 | Thu May 07, 2015 2:39 pm by Frank111 | ||
Interpreting Tube Matching | 6 | Frank111 | 1441 | Thu May 07, 2015 2:38 pm by Roy Mottram | ||
Recent DIY project a new Turntable | 9 | tiguan | 1580 | Wed May 06, 2015 3:41 pm by tiguan | ||
DC panel meter - anyone try this? | 8 | Dallas | 1307 | Tue May 05, 2015 3:14 pm by Dallas | ||
Supply capacitance: how much is too much? | 10 | Dallas | 1279 | Tue May 05, 2015 3:08 am by Dallas | ||
dynaco MK IV amp | 2 | 57blues | 1413 | Sat May 02, 2015 3:02 pm by MarcVBelgium | ||
Dynaco ST70 with Little dot Preamp | 10 | tomerte | 1678 | Fri May 01, 2015 9:01 am by tomerte | ||
Direct Compare of my VTA ST-70 and my VTA Mark III | 3 | edgobb | 1062 | Thu Apr 30, 2015 10:59 am by edgobb |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 2 Guests
Registered Users: None
