Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4150 | Sat Dec 02, 2023 5:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 880 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1379 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
A pre-amp to match my VTA ST70? | 6 | tommyC7 | 1308 | Tue Nov 24, 2020 8:14 am by tomlang | ||
pas filament supply question | 13 | rmk | 1155 | Sun Nov 22, 2020 10:20 am by rmk | ||
Impedance question | 5 | Kinski | 733 | Sat Nov 21, 2020 5:55 pm by Kinski | ||
Where can I find the bias testing post mount thing? | 4 | smoorenc | 1193 | Mon Nov 16, 2020 12:05 am by aguaazul | ||
My very first tube amps! | 18 | VintageRulez | 1479 | Wed Nov 04, 2020 7:01 pm by Solder Slinger | ||
Proper technique to test a pre-amp | 2 | Mr C | 577 | Wed Nov 04, 2020 2:06 pm by Mr C | ||
Low output one channel | 13 | dalemurray | 1266 | Wed Nov 04, 2020 11:59 am by fredeb | ||
Anyone know the completed weight of the 120? | 2 | smoorenc | 614 | Sun Nov 01, 2020 10:18 am by smoorenc | ||
Gold Lion KT-88 Issues? | 6 | Guest | 1914 | Sun Nov 01, 2020 2:20 am by peterh | ||
New Power Cord ST70 Polarity?? | 2 | LBK | 849 | Sat Oct 31, 2020 7:35 pm by corndog71 | ||
Dynatuner FM-3 PB-012 vs PA509 Transformer | 5 | Stannie79 | 927 | Sat Oct 31, 2020 2:04 am by peterh | ||
Bias help. One side not adjusting to proper voltage. | 7 | gjmess | 703 | Thu Oct 29, 2020 4:37 pm by gjmess | ||
Hooking up two turntables | 1 | Dave_in_Va | 431 | Wed Oct 28, 2020 10:21 pm by corndog71 | ||
NOS tubes for my ST-35 | 5 | soundz915 | 453 | Sat Oct 24, 2020 4:57 pm by WLT | ||
ST-35 fuse blown | 20 | soundz915 | 820 | Sat Oct 24, 2020 4:52 pm by WLT | ||
Bias setting for original ST70 | 18 | erniegiro | 3449 | Wed Oct 21, 2020 8:12 pm by erniegiro | ||
Bias question 1, 2 | 46 | Skelt | 2626 | Tue Oct 20, 2020 3:52 pm by Skelt | ||
Need opinions on new equipment acquired | 11 | gjmess | 992 | Tue Oct 20, 2020 10:14 am by peterh | ||
New Octal VTA-70 hiss question | 6 | ttownscott | 787 | Tue Oct 20, 2020 3:20 am by ttownscott | ||
Preamp for ST70 | 21 | jeffjmr | 2321 | Mon Oct 19, 2020 10:59 pm by Roy Mottram | ||
TDR Relay with Tube Rectifier | 10 | jimmeq | 1124 | Sun Oct 18, 2020 3:45 pm by monkuboy | ||
VTA70 board mod advantage of increased capacitance | 4 | erniegiro | 761 | Sat Oct 17, 2020 7:14 pm by erniegiro | ||
Blown Fuse on an original Dynaco ST-70 HELP | 3 | danagr | 819 | Sat Oct 10, 2020 2:46 pm by danagr | ||
12ax7 to 12bz7 | 4 | Tom | 929 | Sat Oct 10, 2020 11:07 am by Tom | ||
Tube Replacement: 6550WE with GZ33 or GL KT88 and 5AR4 | 2 | dalemurray | 995 | Fri Oct 09, 2020 12:03 am by dalemurray | ||
Troubleshooting help needed for brand new VTA ST-120 - solved ! 1, 2 | 45 | alanhuth | 3138 | Thu Oct 08, 2020 3:05 pm by alanhuth | ||
Red Plate, V6 - two year old ST-120 with original 6550 | 8 | dalemurray | 750 | Wed Oct 07, 2020 10:29 pm by dalemurray | ||
Low voltage power transformer | 12 | gwvenus56 | 880 | Mon Oct 05, 2020 4:22 pm by Wharfcreek | ||
How to make your own custom circuit boards with a 3-D printer | 0 | baddog1946 | 450 | Sun Oct 04, 2020 12:04 pm by baddog1946 | ||
Optimal voltage for our amps | 5 | Mr C | 848 | Fri Oct 02, 2020 5:11 pm by audio ken | ||
VTA ST-70 with 12 or 16 ohm speakers | 5 | audio ken | 820 | Thu Oct 01, 2020 5:16 pm by Bob Latino | ||
VTA / MKIII bias resistor | 5 | wgallupe | 835 | Thu Oct 01, 2020 2:50 pm by wgallupe | ||
Need schematic and layout for Dyna PAS preamp | 3 | case310350 | 5001 | Tue Sep 29, 2020 7:57 am by Bob Latino | ||
VTA/PAS4 Build | 4 | stewdan | 1104 | Sun Sep 27, 2020 1:07 pm by peterh | ||
Protect my amp? | 6 | Guest | 763 | Sat Sep 26, 2020 12:38 pm by solderblob | ||
Older VTA ST-120 tubes | 9 | davidness | 1462 | Fri Sep 25, 2020 8:01 am by Bob Latino | ||
Dirty Tube Sockets?!?!?! | 8 | MechEngVic | 2129 | Sun Sep 20, 2020 7:47 pm by DavidR | ||
MKiii Output Transformer | 3 | rudes | 808 | Sat Sep 19, 2020 10:16 pm by stewdan | ||
VTA-70 Tube Amplifier? | 19 | Guest | 1678 | Sat Sep 19, 2020 2:48 am by peterh | ||
Removing Anodization | 3 | Mr C | 685 | Sat Sep 12, 2020 5:05 am by mijohn | ||
Catastrophic failure of auto bias board in M-125 | 10 | FearOfMusic | 2029 | Fri Sep 11, 2020 9:40 pm by aguaazul | ||
ST70 diode warning 1, 2 | 28 | jeffjmr | 3464 | Fri Sep 11, 2020 8:25 pm by jeffjmr | ||
Newbee- Lots of Dynaco Questions | 4 | LBK | 629 | Thu Sep 10, 2020 2:38 am by peterh | ||
VTA-ST70 chassis dimensions | 2 | audio ken | 986 | Tue Sep 08, 2020 12:14 pm by audio ken | ||
Just had a 6550 Red Plate on a VTA-120 | 8 | Hops | 1608 | Thu Sep 03, 2020 1:36 am by peterh | ||
Original Dynakit ST70 - Quad cap is vibrating with the music | 22 | Potato_Head | 1730 | Wed Sep 02, 2020 9:17 pm by Potato_Head | ||
Tube temperature | 2 | MarcVBelgium | 593 | Wed Sep 02, 2020 7:47 am by MarcVBelgium | ||
Stereo 70 Repair Diagnostics & Journal | 4 | misterc57 | 705 | Fri Aug 28, 2020 9:19 am by peterh | ||
Help on Mods original Dynaco ST-70 with VTA board/PAS3X | 9 | Pigboat | 1997 | Mon Aug 24, 2020 2:02 pm by Pigboat | ||
Voltage regulator vs VARIC vs Power Conditioner 1, 2 | 28 | Guest | 3611 | Mon Aug 24, 2020 1:50 pm by Hops |
Sort
Users browsing this forum: 2 Registered, 0 Hidden and 4 Guests
Registered Users: audioregenesis, Bob Latino
