Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4150 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 880 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1379 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
VTA-Board upgrade ST-70? | 1 | tubey1 | 479 | Sun Jan 23, 2022 4:03 pm by Roy Mottram | ||
SP9 Preamp Hum - Only w/Phono Tubes | 1 | tjplatt | 428 | Fri Jan 21, 2022 3:04 pm by Roy Mottram | ||
ST-120 Rectifier Options? | 11 | 98indypacer | 1146 | Fri Jan 21, 2022 2:51 pm by Roy Mottram | ||
VTA ST-120 Wiring For 16ohm Speakers | 1 | Mad Dog | 324 | Fri Jan 21, 2022 2:25 pm by Roy Mottram | ||
VTA ST120 and Infinity Kappa 7's | 2 | thevic24 | 274 | Fri Jan 21, 2022 12:40 pm by thevic24 | ||
ST120 click/flash in one tube | 16 | grosen | 1038 | Thu Jan 20, 2022 6:18 pm by Bob Latino | ||
Auto Bias board for VTA ST120 - do the LEDs really need to be visible | 3 | ChetJettison | 547 | Tue Jan 18, 2022 3:43 pm by New2Tubez | ||
Comprehensive tube list??? | 9 | Rbertalotto | 2274 | Mon Jan 17, 2022 8:12 pm by hottyson | ||
VTA-120 all in 1 (almost) PCB | 8 | Chad Spackman | 1238 | Sat Jan 15, 2022 9:43 am by Chad Spackman | ||
ignore, posted in the wrong place. | 0 | misterc57 | 290 | Fri Jan 14, 2022 4:06 pm by misterc57 | ||
M-125 break-in with Dummy load resistor. | 2 | Beanhead | 428 | Wed Jan 12, 2022 5:15 pm by Beanhead | ||
new amp style - vote your opinion ! 1, 2 | 32 | Roy Mottram | 2554 | Sun Jan 09, 2022 2:24 pm by New2Tubez | ||
Panor / Dynaco ST80 - distortion one channel at higher volumes | 12 | boeingpilot | 1295 | Fri Jan 07, 2022 6:26 am by boeingpilot | ||
PAS Signal Chain Weirdness... What should a square wave look like as it goes through the gain stages? | 4 | kenmwallace | 458 | Fri Jan 07, 2022 1:39 am by Roy Mottram | ||
PAS3X Phono Pre-amp | 2 | radiojer | 634 | Thu Jan 06, 2022 2:12 pm by audioregenesis | ||
Hook up wire for SP12/PH6 combo | 1 | duder1982 | 400 | Sun Jan 02, 2022 10:52 pm by duder1982 | ||
Taking a brake everyone....:-) | 2 | Tom Pickett | 885 | Thu Dec 30, 2021 5:55 pm by New2Tubez | ||
Original Dynaco ST-70 120hz intermittent low hum with new EL34 tubes | 5 | Bainbridge | 848 | Wed Dec 29, 2021 2:41 pm by Seamus | ||
Hum problem on one channel | 6 | Telescope12 | 504 | Wed Dec 29, 2021 11:50 am by corndog71 | ||
ST-70 VTA Driver and Triode Cap Board upgrade results. | 0 | Sfguitarworks | 693 | Mon Dec 27, 2021 6:15 pm by Sfguitarworks | ||
Help with new to me ST-120 Stereo Amplifier - Scratchy noise in right channel 1, 2 | 30 | Peacemaker | 2032 | Tue Dec 14, 2021 10:19 pm by MechEngVic | ||
Scratchy noise noise from your amp | 0 | rembrandt! | 429 | Tue Dec 14, 2021 7:32 am by rembrandt! | ||
VTA ST 70 16 ohm output to speakers | 9 | Dave_in_Va | 1161 | Mon Dec 13, 2021 9:46 pm by Mad Dog | ||
Stepper Type Level Control available??? | 9 | Rbertalotto | 692 | Mon Dec 13, 2021 5:07 pm by Bob Latino | ||
NOOB Here... | 10 | Mission | 1425 | Sat Dec 11, 2021 9:42 pm by Mission | ||
VTA M-125 hum | 2 | syrinxcs | 743 | Sat Dec 11, 2021 3:57 pm by Tom | ||
Selling ST120...Maybe | 5 | Rbertalotto | 966 | Sat Dec 11, 2021 3:03 pm by Rbertalotto | ||
Eastern PA help needed with st70 | 4 | Huck | 641 | Thu Dec 09, 2021 4:51 pm by WLT | ||
ST120 left channel dropping out - problem solved ! | 15 | ChetJettison | 751 | Wed Dec 08, 2021 9:29 am by Bob Latino | ||
ST120 Driver Tubes: Should they all be the same? | 4 | ChetJettison | 933 | Tue Dec 07, 2021 10:26 am by DavidR | ||
A-430 or A-431 winding | 5 | fobya71 | 1479 | Thu Dec 02, 2021 10:44 am by stewdan | ||
KEF LS50 Meta with VTA ST120 | 1 | Rbertalotto | 459 | Thu Nov 25, 2021 7:42 pm by Bob Latino | ||
Tetrode Tubes with Triode Switch Mod on Dynakit St70 | 3 | immemory | 603 | Sat Nov 20, 2021 4:06 pm by peterh | ||
Anyone tried jb Capacitors in a PAS | 1 | breading | 556 | Fri Nov 19, 2021 1:03 pm by corndog71 | ||
A bright flash, a low dull thunk and diminished volume 1, 2, 3 | 63 | Mr C | 3902 | Thu Nov 18, 2021 7:29 pm by Andy Jersey | ||
Average life of an OT? | 5 | Guest | 1079 | Thu Nov 18, 2021 5:19 pm by Jim McShane | ||
Pas Loses audio In One Channel | 2 | rudes | 426 | Wed Nov 17, 2021 9:22 pm by Dave_in_Va | ||
Thank you Bob Latino... | 22 | AmpedUp | 2119 | Wed Nov 17, 2021 9:49 am by Section1 | ||
M-125 volume problem - fixed ! 1, 2 | 27 | IntarsiaGuy | 1746 | Mon Nov 15, 2021 9:42 pm by Bob Latino | ||
My life is ruined... | 5 | rustybutt | 1621 | Fri Nov 12, 2021 7:11 pm by Roy Mottram | ||
Analog Bias Meters For The VTA ST-120 | 12 | Tom Pickett | 2406 | Fri Nov 12, 2021 6:59 pm by Roy Mottram | ||
Dynaco SCA-35 hum/ground issue | 2 | Vimmy | 750 | Fri Nov 12, 2021 2:33 pm by boscode | ||
TriodeUSA ST-70 amp clipping below rated output | 16 | jeffjmr | 1277 | Mon Nov 01, 2021 2:45 pm by jeffjmr | ||
Opinions - Bad Recordings + Revealing Speakers + Triode Mode | 10 | IntarsiaGuy | 1214 | Sun Oct 31, 2021 2:29 pm by New2Tubez | ||
Dynaco PAS 3 Hum | 9 | breading | 1298 | Sat Oct 30, 2021 3:10 am by peterh | ||
Build ST35 with 6V6 rather than EL84? | 2 | len42 | 824 | Fri Oct 29, 2021 9:41 pm by corndog71 | ||
online preamps? | 6 | edman44 | 777 | Fri Oct 29, 2021 2:33 pm by Tube Nube | ||
Biasing - Ultralinear vs Triode mode. | 2 | boeingpilot | 765 | Fri Oct 29, 2021 1:29 pm by boeingpilot | ||
6SN7 Driver Board Alternate Uses | 1 | TN Allen | 746 | Wed Oct 27, 2021 12:29 pm by Roy Mottram | ||
ST-120 Problems | 2 | RogerRef | 901 | Mon Oct 25, 2021 8:04 am by Bob Latino |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 4 Guests
Registered Users: None
