Basket
Topics | Replies | Author | Views | Last Posts | ||
Center 12AU7 bright on start-up | 2 | Brap | 314 | Tue Dec 13, 2022 9:34 am by Brap | ||
M125 No sound | 1 | rwbaker | 374 | Tue Dec 13, 2022 9:19 am by Bob Latino | ||
Strange output behavior, VTA ST70 with speakers | 6 | docswanson | 778 | Fri Dec 09, 2022 4:30 pm by Roy Mottram | ||
Vacuum Tube Values.com | 4 | Brap | 965 | Sat Dec 03, 2022 4:12 am by MechEngVic | ||
Quad Cap Question for ST-70 | 2 | litefootdan | 1026 | Wed Nov 30, 2022 3:32 pm by litefootdan | ||
VTA ST-120 Coming Out of Mothballs | 0 | arledgsc | 582 | Wed Nov 23, 2022 11:20 am by arledgsc | ||
st-70 Telefunken driver tubes | 1 | Brap | 386 | Tue Nov 22, 2022 2:39 am by peterh | ||
Dynaco paint question | 5 | WLT | 697 | Mon Nov 21, 2022 7:51 pm by David1948 | ||
ST120 with no speakers connected??? | 4 | Rbertalotto | 357 | Sun Nov 20, 2022 1:37 pm by Rbertalotto | ||
Just Wondering | 2 | jwb474 | 390 | Sun Nov 20, 2022 1:36 am by jwb474 | ||
Scratchy noise from one channel in new ST-70 build after 5 weeks | 4 | bootstrapjesse | 654 | Sun Nov 13, 2022 9:57 pm by bootstrapjesse | ||
st 70 ,new to tubes | 2 | zapped1 | 397 | Sun Nov 13, 2022 1:55 am by zapped1 | ||
ST 70 power transformer | 3 | zapped1 | 536 | Sat Nov 12, 2022 7:10 pm by Roy Mottram | ||
5U4G new rectifier replacement | 2 | baddog1946 | 532 | Sat Nov 12, 2022 7:09 pm by Roy Mottram | ||
A Question About ST-70 Can Capacitor Upgrades | 15 | quadaptor | 12321 | Tue Nov 08, 2022 11:09 am by Bob Latino | ||
HUM, HUM ISSUES (resolved !) | 13 | pedrocols | 903 | Mon Nov 07, 2022 12:44 pm by pedrocols | ||
Noisy MK IV amps. SOLVED Trouble shooting insight appreciated. | 5 | fasturd | 769 | Fri Nov 04, 2022 3:15 pm by fasturd | ||
VTA-120 Possible Pentode/Triode Switch Problems | 7 | jimmeq | 675 | Mon Oct 31, 2022 6:03 pm by jimmeq | ||
Which Version VTA 70 Is This? | 6 | knotscott | 912 | Mon Oct 31, 2022 8:36 am by Bob Latino | ||
Which NOS 6AN8A? | 3 | rembrandt! | 483 | Sun Oct 30, 2022 9:23 pm by MechEngVic | ||
Dyna PAS 2 for the group | 6 | WLT | 968 | Sun Oct 16, 2022 10:52 pm by daveshel | ||
Keep blowing Weber WZ68 rectifier on ST-120 | 4 | nathico | 815 | Sat Oct 08, 2022 1:20 pm by nathico | ||
PH14 With Volume Control | 4 | Rec | 595 | Sat Oct 08, 2022 10:57 am by Rec | ||
Strange set of RCA EL34s. Any idea about the design? | 2 | ccarlton28 | 641 | Mon Oct 03, 2022 8:57 pm by Jim McShane | ||
ST-70 what is a safe input VAC | 11 | raudio44 | 752 | Fri Sep 30, 2022 8:56 am by Brap | ||
VTA ST120 - Lost right channel, help needed | 9 | willythree | 1344 | Wed Sep 28, 2022 11:47 pm by rebellovw | ||
Brand New PSVane KT88s blew 3 fuses and 3 5AR4 Rectifiers in ST70 | 14 | arremondo | 1683 | Tue Sep 27, 2022 5:38 pm by Roy Mottram | ||
ST-120 tube redplate. Not a bad cathode resistor. what to check? | 5 | ChetJettison | 417 | Tue Sep 27, 2022 1:59 pm by peterh | ||
VTA 120 hum then high voltage at one pin | 1 | Beachlandguy | 396 | Wed Sep 21, 2022 2:26 am by peterh | ||
PH16 tube rolling positions question | 19 | mdelrossi | 2017 | Fri Sep 16, 2022 1:05 pm by carlsor | ||
PAS Circuit Question | 2 | breading | 565 | Fri Sep 16, 2022 12:15 am by daveshel | ||
Coupling caps for 6SN7 driver board question | 1 | Telescope12 | 598 | Mon Sep 12, 2022 3:43 pm by Bob Latino | ||
MK3s new build issue | 5 | MHProd | 757 | Sun Sep 11, 2022 12:55 am by MechEngVic | ||
Bad mechanical hum after installing Chinese "KT88" PSvane tubes and blowing 4 rectifiers | 9 | arremondo | 1115 | Sun Sep 11, 2022 12:44 am by MechEngVic | ||
85 deg C capacitor--advisable for VTA board? | 2 | colin86325 | 401 | Sat Sep 10, 2022 2:00 pm by colin86325 | ||
Rebuilding my M125s - can I use this cap in the SCM module? 1, 2, 3 | 56 | rebellovw | 3904 | Wed Sep 07, 2022 3:10 pm by rebellovw | ||
Psvane KT88C and ST-120 | 5 | smoorenc | 1294 | Tue Sep 06, 2022 12:13 pm by New2Tubez | ||
ST-70 chassis ground | 4 | bootstrapjesse | 769 | Sun Sep 04, 2022 4:23 pm by bootstrapjesse | ||
Interesting ST 70 | 1 | Dave_in_Va | 679 | Tue Aug 30, 2022 5:39 pm by Bob Latino | ||
Increase Bias Supply -Voltage | 6 | TubesGlo | 1203 | Wed Aug 17, 2022 10:07 pm by fredeb | ||
Mark 3 fuse blows after hours of use | 7 | jrethorst | 728 | Wed Aug 17, 2022 1:33 pm by Bob Latino | ||
[ Poll ] New PCB color option? | 1 | Dan W | 898 | Mon Aug 15, 2022 8:29 pm by Gabriel | ||
Stereo/Mono Switch.... | 5 | wolverine | 10902 | Fri Aug 12, 2022 7:08 am by lorne | ||
PCB Color Polls | 2 | jwb474 | 428 | Fri Aug 05, 2022 11:18 am by DavidR | ||
Paint Color? | 2 | Joe302 | 620 | Tue Aug 02, 2022 4:03 pm by Joe302 | ||
ST-70 NO BIAS | 14 | joseramonnavarro | 924 | Thu Jul 28, 2022 6:21 pm by Roy Mottram | ||
New PSVANE KT88 and my Dynaco MK3s | 4 | bubbasweet | 827 | Wed Jul 27, 2022 6:05 pm by arremondo | ||
Starting the st120 up without speakers | 6 | Guest | 700 | Tue Jul 26, 2022 8:14 am by cci1492 | ||
EL 34 tubes in Mark 3 amp | 14 | jrethorst | 980 | Thu Jul 21, 2022 3:10 pm by WLT | ||
Dyna Mk lll question | 6 | MarkS57 | 669 | Thu Jul 21, 2022 9:52 am by peterh |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
