Basket
Topics | Replies | Author | Views | Last Posts | ||
Bob Latino's VTA ST-120 Label Badge Chocolate Brown on Brass :-) | 19 | Tom Pickett | 1442 | Wed Apr 06, 2022 4:05 pm by Bob Latino | ||
Hi, new to me ST-70 .. a question | 7 | mattnew | 1320 | Tue Apr 05, 2022 12:18 pm by Solder Slinger | ||
It's Not Just Electro-Harmonix, Our Hobby in Standstill | 6 | jwb474 | 1014 | Sat Apr 02, 2022 5:57 pm by Tubes4ever | ||
DYNA kIT st-70 -- OLD MODS -- Audio amatuer 1976 | 2 | DYNAblow86 | 661 | Sat Apr 02, 2022 5:32 pm by steve46 | ||
FS: New Raw Printed Circuit Boards for the M125 monoblock | 0 | ron12n33 | 348 | Sat Apr 02, 2022 12:05 pm by ron12n33 | ||
VTA ST70 Review | 1 | ltusler | 788 | Fri Apr 01, 2022 11:43 pm by Roy Mottram | ||
mk3 distortion and low volume | 1 | pittsburghpaints | 289 | Fri Apr 01, 2022 2:31 am by peterh | ||
ST-70 Early driver board installation instructions needed | 0 | fxbill1 | 407 | Thu Mar 31, 2022 8:05 pm by fxbill1 | ||
ST-70 Bad Output Trans? | 0 | rudes | 436 | Thu Mar 31, 2022 6:27 pm by rudes | ||
ST-70 Bias Drift | 2 | justin_122 | 854 | Wed Mar 30, 2022 9:16 pm by Roy Mottram | ||
Hi, I am looking for someone to test some tubes . | 0 | Caps poor | 290 | Wed Mar 30, 2022 7:25 pm by Caps poor | ||
The Western Electric plant in Rossville, GA USA will be starting to make tubes again. | 8 | Bob Latino | 1069 | Tue Mar 29, 2022 9:16 pm by Gabriel | ||
Custom Built Dynaco MK III - Bias Question | 7 | scuba100 | 1014 | Sun Mar 27, 2022 7:38 pm by scuba100 | ||
VTA M-125 on 2 tubes | 5 | ranges | 570 | Thu Mar 24, 2022 11:56 am by corndog71 | ||
New VTA ST-120 Kit | 1 | N5 | 483 | Wed Mar 23, 2022 9:48 am by Brap | ||
Newsensor/Electro-Harmonix has this notification on their web site | 13 | Bob Latino | 1260 | Tue Mar 22, 2022 2:20 pm by rebellovw | ||
VTA ST-70 problem | 11 | Chris A | 1753 | Sun Mar 20, 2022 10:47 pm by Gabriel | ||
What have I found here? | 3 | ADMsystems | 988 | Sun Mar 20, 2022 3:37 pm by ADMsystems | ||
Fun times..... | 4 | cci1492 | 658 | Sat Mar 19, 2022 7:24 pm by New2Tubez | ||
Wandering Bias on M125 | 2 | bcinnamon | 533 | Thu Mar 17, 2022 10:27 am by rebellovw | ||
Dynaco VTA ST70 Docking station? | 2 | tubey1 | 780 | Sat Mar 12, 2022 10:54 pm by tubey1 | ||
WZ68 is not designed for use in HIFI amps?? | 13 | Gabriel | 1587 | Fri Mar 04, 2022 2:35 pm by Wotan | ||
K-12G amplifier build | 0 | Rbertalotto | 400 | Fri Mar 04, 2022 1:40 pm by Rbertalotto | ||
new amp style for 2022 1, 2 | 35 | Roy Mottram | 4301 | Fri Mar 04, 2022 12:06 am by 98indypacer | ||
PH16 Hum pcb loop. | 6 | FearOfMusic | 801 | Thu Mar 03, 2022 5:55 pm by levconz | ||
VTA-120 Power Transformer | 2 | theboxer | 771 | Thu Mar 03, 2022 3:45 pm by theboxer | ||
SP 14 Uneven Gain | 4 | manookjs | 640 | Thu Mar 03, 2022 2:30 pm by Roy Mottram | ||
Dynaco PAM 1 PC board | 6 | teknofossil | 633 | Thu Mar 03, 2022 11:15 am by 1973shovel | ||
Gold Lion Tubes | 2 | Brap | 773 | Tue Mar 01, 2022 3:54 pm by Brap | ||
Noisy ST120 amplifier | 1 | Gabriel | 555 | Tue Mar 01, 2022 10:06 am by Gabriel | ||
What a wildfire does to M-125 amplifiers | 10 | JXBJXB | 1247 | Sun Feb 27, 2022 12:18 pm by colin86325 | ||
Hi-Gain vs. Lo-Gain | 4 | craigtone | 4413 | Sun Feb 27, 2022 3:22 am by Roy Mottram | ||
Properly seated valves. | 5 | Gabriel | 754 | Tue Feb 22, 2022 1:20 pm by rebellovw | ||
P782S substitute | 5 | Monotriode | 686 | Fri Feb 18, 2022 10:11 am by WLT | ||
New AC plug wiring for ST-70 | 10 | cc43fan | 3953 | Thu Feb 17, 2022 3:03 pm by Chip2020 | ||
Anyone Modify M125 for Individual Bias? | 11 | 98indypacer | 654 | Thu Feb 17, 2022 2:39 pm by ttocs | ||
Another version of the amplifier | 12 | Juris | 1816 | Thu Feb 17, 2022 8:44 am by Juris | ||
Painting Transformer Bells? | 9 | 98indypacer | 1627 | Wed Feb 16, 2022 11:22 pm by 98indypacer | ||
PH16 Phono Preamp Moving Coil Cart? | 4 | harryc | 720 | Tue Feb 15, 2022 10:18 pm by harryc | ||
Wire used for the ST120 connections. | 6 | Gabriel | 792 | Sun Feb 13, 2022 8:19 am by Gabriel | ||
Adding A choke To My ST-35 Kit Amp | 20 | JimOfOakCreek | 3922 | Sat Feb 12, 2022 10:27 am by peterh | ||
Blown Bias Resistor - Did I Mess Up? | 20 | jasn54 | 3179 | Thu Feb 10, 2022 4:46 pm by Gabriel | ||
New construction st120 1, 2 | 32 | jonny6336 | 4347 | Thu Feb 10, 2022 3:22 pm by Roy Mottram | ||
AC mains cord connection for the ST120 in Australia | 1 | Gabriel | 334 | Sat Feb 05, 2022 6:22 am by Gabriel | ||
Dynaco ST-70 Series 3 | 16 | Spoon | 1423 | Tue Feb 01, 2022 3:24 pm by johprice | ||
Dynaco Stereo 70 Bias Adjust Issue | 17 | misterc57 | 1714 | Tue Feb 01, 2022 3:06 pm by peterh | ||
ST-70 Series 3 Tube Selection. Too Bright. | 4 | johprice | 660 | Mon Jan 31, 2022 9:46 pm by corndog71 | ||
VTA Nichicon Cap Upgrade? | 5 | B&WTube | 865 | Mon Jan 31, 2022 2:38 pm by pedrocols | ||
VTA M-125 21 Step Attenuator? | 0 | 98indypacer | 341 | Sun Jan 30, 2022 9:58 pm by 98indypacer | ||
M125 with Octal Adapters | 0 | Rec | 444 | Fri Jan 28, 2022 4:23 pm by Rec |
Sort
Users browsing this forum: 3 Registered, 0 Hidden and 1 Guest
Registered Users: audioregenesis, Blitzen, jimmeq
