Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4146 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 878 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1377 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
16 ohm speakers | 9 | Roy Mottram | 1183 | Sun Oct 24, 2021 10:10 am by TN Allen | ||
Noise from 1 channel. I have tried the following so far and no luck. Suggestions? | 13 | smoorenc | 1058 | Sat Oct 23, 2021 7:36 am by smoorenc | ||
Troubleshooting VTA-70, First Time | 10 | bbrater | 1072 | Sat Oct 16, 2021 3:57 pm by bbrater | ||
M-125 Output Impedance Tricks? 1, 2, 3 | 51 | ttocs | 3331 | Wed Oct 13, 2021 2:27 pm by pedrocols | ||
VTA 120 output tube red plated -- what do you check if you're using the AB board? | 11 | Guest | 1039 | Wed Oct 13, 2021 1:30 pm by Guest | ||
Modified Dynaco ST70 | 8 | NSacchetti | 1655 | Tue Oct 12, 2021 1:49 pm by ELBill34 | ||
Original MK3 and ST70 Bias settings, Why? | 3 | jwb474 | 984 | Tue Oct 12, 2021 7:22 am by Bob Latino | ||
PAS 3 Balance Control Replacement Options? | 5 | breading | 1073 | Fri Oct 08, 2021 9:25 pm by Roy Mottram | ||
Very low bias and hum on Dynakit ST-70 1, 2 | 36 | lagwil | 4277 | Wed Oct 06, 2021 1:58 pm by DC92 | ||
ST-70 speaker recommendation? 1, 2 | 40 | raudio44 | 4166 | Tue Oct 05, 2021 4:41 am by raudio44 | ||
opiniion survey on amplifier style | 14 | Roy Mottram | 1525 | Mon Sep 27, 2021 10:27 pm by Roy Mottram | ||
VTA-ST120 Bias resistor settings, | 5 | edman44 | 1028 | Mon Sep 27, 2021 10:23 pm by Roy Mottram | ||
6dj8 in a ph16? | 2 | EWALAA | 570 | Mon Sep 27, 2021 10:17 pm by Roy Mottram | ||
Tight tube sockets | 4 | docswanson | 853 | Sat Sep 18, 2021 1:47 pm by docswanson | ||
M125 AutoBias Goes Out | 9 | IntarsiaGuy | 1525 | Wed Sep 15, 2021 12:59 pm by pavlikkkk | ||
5AR4 for Pas | 1 | Tube747 | 559 | Tue Sep 14, 2021 10:15 am by peterh | ||
Autobias board question | 1 | Guest | 979 | Sun Sep 12, 2021 3:46 pm by pavlikkkk | ||
Help with a markIII - very low output | 5 | EWALAA | 747 | Thu Sep 09, 2021 9:21 pm by EWALAA | ||
Is it OK to bypass the Selenium like this? | 5 | bubbasweet | 556 | Thu Sep 09, 2021 3:20 pm by danielrhall | ||
FM-1 Multiplexer Board anyone have one for sale? | 1 | bubbasweet | 396 | Tue Sep 07, 2021 4:24 am by jwb474 | ||
Impedance Curve vs Manufacturer Nominal | 0 | texbychoice | 293 | Mon Sep 06, 2021 11:35 am by texbychoice | ||
FM-1 Coil home repair. | 2 | bubbasweet | 636 | Sun Sep 05, 2021 2:05 pm by bubbasweet | ||
SP12 preamp revisited | 1 | Roy Mottram | 7606 | Sat Sep 04, 2021 5:42 pm by Roy Mottram | ||
KT-120 electric shock | 3 | alexbramford | 1016 | Thu Sep 02, 2021 10:53 am by Bob Latino | ||
Heartbeat-like thumping in speakers? ST-70 > PAS-3 | 13 | DC92 | 1001 | Tue Aug 31, 2021 3:09 pm by DC92 | ||
Dynaco FM-1 Hum on high bass | 3 | bubbasweet | 582 | Tue Aug 31, 2021 11:53 am by bubbasweet | ||
Differences between the Dynaco PAS 2/3 and the PAS-3X preamps | 2 | Bob Latino | 2461 | Fri Aug 27, 2021 3:21 pm by jwb474 | ||
Dyna PAS3 voltage question | 10 | Pablo | 1194 | Fri Aug 27, 2021 1:40 pm by Wharfcreek | ||
KT120 power tubes blowing fuses and bias resistors in the ST-120 | 2 | alexbramford | 1166 | Mon Aug 23, 2021 7:47 am by Bob Latino | ||
ST-70 rectifier question | 6 | raudio44 | 1018 | Fri Aug 20, 2021 4:27 am by raudio44 | ||
Carbon Resistors on Power Supply Caps replace or not | 5 | bubbasweet | 609 | Thu Aug 19, 2021 10:41 am by bubbasweet | ||
Thank you Bob ST-70 | 0 | raudio44 | 507 | Wed Aug 18, 2021 7:15 am by raudio44 | ||
Dynaco VTA-ST120 yellow sheet diode mod. | 2 | edman44 | 1188 | Tue Aug 17, 2021 11:24 pm by edman44 | ||
My 2 VTA ST 120 Choke Mesurments. | 3 | Tom Pickett | 569 | Mon Aug 16, 2021 3:59 pm by edman44 | ||
My first Dynaco ST-70 with VTA driver board rebuild | 4 | docswanson | 1160 | Sun Aug 15, 2021 2:34 pm by knotscott | ||
Time Delay Relay For Pre-Amps/Small Power Amps. | 2 | jwb474 | 517 | Fri Aug 13, 2021 8:01 pm by Tubes4ever | ||
vta driver tube change & sound question 1, 2 | 42 | paysonmark | 2169 | Thu Aug 12, 2021 9:05 pm by Cl75 | ||
Restore Three Mark II Amps 1, 2, 3 | 59 | johnmeyer | 3256 | Wed Aug 11, 2021 8:58 pm by johnmeyer | ||
Driver tube replacement | 11 | Sfguitarworks | 1610 | Mon Aug 09, 2021 1:29 am by pavlikkkk | ||
PAS 3 capacitor functions on the line stage board 5 | 1 | smype | 516 | Sat Aug 07, 2021 8:18 pm by peterh | ||
SP14 hum during warmup | 2 | bobgroger | 964 | Fri Aug 06, 2021 10:35 am by ixe13 | ||
Post a PDF File | 1 | jwb474 | 531 | Thu Aug 05, 2021 7:19 pm by Roy Mottram | ||
Dyanco VTA-PA-060-120 DP Transformer. | 2 | edman44 | 570 | Thu Aug 05, 2021 2:35 pm by edman44 | ||
ST-120 and summer time voltage swings | 2 | DavidR | 545 | Mon Aug 02, 2021 7:03 pm by DavidR | ||
Optimal Cap Values for PAM1 PS-1 Restoration Hum Reduction | 0 | bubbasweet | 367 | Mon Aug 02, 2021 12:52 pm by bubbasweet | ||
Setting bias on Mk 3 -- speaker connection required? | 1 | jrethorst | 637 | Sun Aug 01, 2021 7:39 am by Bob Latino | ||
Hum/Hiss/Static out of Left Channel (Speaker) | 17 | Chipster1969 | 1163 | Fri Jul 30, 2021 8:28 am by Chipster1969 | ||
When replacing the PC 5 board with new on the PAS-2 soldered clips | 4 | bubbasweet | 321 | Wed Jul 28, 2021 11:41 am by bubbasweet | ||
Speaker terminal wiring for VTA70 upgrade | 4 | erniegiro | 1386 | Wed Jul 28, 2021 8:15 am by Bob Latino | ||
VTA st-70 amplifier | 1 | Latts | 854 | Sun Jul 25, 2021 11:43 am by Bob Latino |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 2 Guests
Registered Users: None
