Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4103 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 857 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1367 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
Amazon.com Customer Reviews: Wattgate 381 Audio Grade Duplex Socket | 15 | GP49 | 3699 | Wed Jun 22, 2011 10:42 pm by frank | ||
PAS TCLA Tone Control Line Amp Noise Problem | 0 | Guest | 1799 | Wed Jun 22, 2011 1:40 am by Guest | ||
measurable resistor noise | 1 | sailor | 1343 | Tue Jun 21, 2011 8:19 pm by Bob Latino | ||
FM-3 rebuild | 2 | baddog1946 | 4082 | Tue Jun 21, 2011 9:30 am by baddog1946 | ||
Power transformer dynaco mark 4 | 2 | mirco64 | 1219 | Mon Jun 20, 2011 2:54 pm by mirco64 | ||
Square waves | 2 | ramon68 | 2630 | Sun Jun 19, 2011 6:18 pm by JunkyJan | ||
PAS 2/3: Making a connector strip from a copper PCB | 3 | jerdobi | 4843 | Sun Jun 19, 2011 5:05 pm by snav | ||
Painting the transformers in a ST120 kit. Why pull two screws and not all? Just curious. thanks. | 11 | JD2 | 3221 | Sat Jun 18, 2011 7:43 pm by j beede | ||
ST70 resistors replacement | 1 | maninmac771 | 1944 | Sat Jun 18, 2011 5:13 am by Bob Latino | ||
Low output mc phono preamp options | 2 | ramon68 | 1556 | Thu Jun 16, 2011 6:01 pm by Tube Nube | ||
ST70 Attenuator Noise | 3 | Bugs | 1763 | Thu Jun 16, 2011 9:14 am by Bugs | ||
FM Receiver | 3 | mantha3 | 1619 | Thu Jun 16, 2011 8:42 am by mantha3 | ||
FMA-2 Insert Amplifier | 0 | Guest | 1027 | Tue Jun 14, 2011 2:52 pm by Guest | ||
Dynakit ST 35-BCU installation in a non Dynakit amp. | 4 | Tazsmonn | 2478 | Tue Jun 14, 2011 2:22 pm by Tazsmonn | ||
st-70 rebuild hum | 11 | krebob | 4060 | Tue Jun 14, 2011 12:22 pm by mantha3 | ||
The Truth about the M125 Mono Blocks from a novice | 8 | shaunst | 11602 | Tue Jun 14, 2011 8:55 am by mantha3 | ||
ONE CHANNEL problem (dynaco 70 and patI) | 1 | tubesrock | 1133 | Mon Jun 13, 2011 11:31 pm by Roy Mottram | ||
Passive Pre Amp | 3 | mantha3 | 3082 | Sun Jun 12, 2011 9:39 am by mantha3 | ||
ST120 Bias pots, cleaning. | 9 | ArlanB | 2624 | Sat Jun 11, 2011 9:56 pm by ArlanB | ||
Shielded power cord ? | 2 | Scott R | 1807 | Sat Jun 11, 2011 1:04 pm by Scott R | ||
Has anyone tried using the 6u8a in place of 7199? | 3 | j beede | 2495 | Sat Jun 11, 2011 7:50 am by wolverine | ||
Inexpensive Line Voltage changer | 5 | terry37932 | 3010 | Fri Jun 10, 2011 10:10 pm by Sal | ||
Input regulation pot? | 9 | Greg_M | 1244 | Thu Jun 09, 2011 5:35 pm by j4570 | ||
550v for MK III KT-88 | 2 | snav | 1181 | Thu Jun 09, 2011 12:14 am by snav | ||
Interconnect cables - Passive Pre > ST120 Tube Amp | 18 | mantha3 | 5568 | Wed Jun 08, 2011 5:37 am by Newportcycle | ||
JJ E34L Bias in the ST-70 | 7 | calinet6 | 4663 | Tue Jun 07, 2011 2:51 pm by calinet6 | ||
Tube tester | 3 | davek65 | 2333 | Sun Jun 05, 2011 9:34 am by Westy56 | ||
To those who spam this board | 1 | Bob Latino | 1326 | Sat Jun 04, 2011 7:53 pm by Greg_M | ||
I'm in - new ST-70! | 19 | johnnybgood | 4269 | Thu Jun 02, 2011 7:36 pm by Westy56 | ||
crazy runs in factory transformer paint? | 1 | j beede | 2614 | Wed Jun 01, 2011 9:43 pm by DynakitParts | ||
Which Deoxit for pots? | 3 | j beede | 2337 | Wed Jun 01, 2011 6:03 pm by j4570 | ||
ST-70 with glowing plates | 2 | j beede | 1849 | Wed Jun 01, 2011 11:13 am by Bob Latino | ||
want another mod and have 3 original ST70 | 13 | dynacophil | 2887 | Tue May 31, 2011 10:55 pm by j4570 | ||
A Tube Preamp Project? | 3 | Greg_M | 3356 | Tue May 31, 2011 4:31 pm by Greg_M | ||
KT88's in a MkII? | 10 | terry37932 | 2339 | Mon May 30, 2011 7:57 pm by Bob Latino | ||
Bob Carver's new 900 watt monoblock amps - photos and link | 6 | Bob Latino | 9243 | Thu May 26, 2011 12:55 pm by natoe | ||
Oscilloscope Specs. Question | 2 | merlot | 1338 | Thu May 26, 2011 7:47 am by j4570 | ||
Dynaco Mark III Factory-Built Versus Kit | 1 | stewdan | 2394 | Wed May 25, 2011 11:07 pm by DynakitParts | ||
Unknown MkII Driver Board | 2 | terry37932 | 1152 | Wed May 25, 2011 11:51 am by Roy Mottram | ||
Final step in PS refurb | 1 | Westy56 | 3191 | Wed May 25, 2011 10:57 am by GP49 | ||
PA-060 Heatsink | 16 | Sled108 | 6689 | Wed May 25, 2011 9:35 am by Westy56 | ||
Classic Dynaco speaker forum - link | 3 | Bob Latino | 6198 | Tue May 24, 2011 5:36 am by dynacophil | ||
PAS3 Power Supply rebuild questions | 5 | j4570 | 2131 | Mon May 23, 2011 8:50 pm by j4570 | ||
Replacement Power Transformer for MkII/MkIII | 1 | terry37932 | 2576 | Mon May 23, 2011 3:42 pm by Bob Latino | ||
Coupling cap value- preamp, amp | 3 | Pooch | 2010 | Mon May 23, 2011 12:36 am by GP49 | ||
Live voltage from chasis of ST70 | 1 | maninmac771 | 1687 | Sun May 22, 2011 4:28 am by GP49 | ||
Capcitor heat | 4 | snav | 1107 | Sat May 21, 2011 8:39 pm by wolverine | ||
"Audiophiles"A simple but inspirational explanation of what we do and why there are so many ways to do it. | 4 | baddog1946 | 1408 | Sat May 21, 2011 8:14 am by wolverine | ||
st70 power transformer question | 2 | wianieq | 1252 | Fri May 20, 2011 3:21 pm by wianieq | ||
Need help with biasing MKIII | 14 | LiqTenExp | 6511 | Fri May 20, 2011 9:42 am by we |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
