Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4123 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 865 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1374 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
Blonder-Tongue EQ | 3 | Guest | 1272 | Wed Mar 19, 2014 6:52 pm by Guest | ||
Valves To Change Tonality in VTA ST-120 | 7 | EddieGnz1 | 1135 | Wed Mar 19, 2014 1:57 pm by sKiZo | ||
better suited resistors | 6 | Guest | 1342 | Wed Mar 19, 2014 9:14 am by Bob Latino | ||
Preamp Comparison | 2 | TN Allen | 1495 | Wed Mar 19, 2014 8:01 am by TN Allen | ||
ST70 & MKIII chassis etc | 3 | Guest | 1155 | Wed Mar 19, 2014 6:54 am by pmarcin | ||
Visual Analyzer (Spectrum Analyzer, Scope, Function Gen) | 12 | mazeeff | 2144 | Tue Mar 18, 2014 1:39 pm by mazeeff | ||
"Telefunken" tubes back in production ?? | 17 | Bob Latino | 3272 | Mon Mar 17, 2014 10:46 am by sailor | ||
My new Sp14 build 1, 2 | 39 | pigface | 9666 | Mon Mar 17, 2014 2:21 am by mijohn | ||
tube based headphone amp | 10 | Guest | 1635 | Sun Mar 16, 2014 12:52 pm by gener8r | ||
hey HEY! It's ALIVE!! | 6 | Dingojazz | 1482 | Sat Mar 15, 2014 8:01 pm by sKiZo | ||
SP14: two issues and need some help | 5 | Laminarman | 1238 | Fri Mar 14, 2014 9:49 am by Zimmer64 | ||
Philips 5R4GYS rectifier ok in ST-70 ? | 8 | deluxmon | 2730 | Fri Mar 14, 2014 12:40 am by sKiZo | ||
Driver tubes M-125 or? | 6 | ac2 | 1993 | Thu Mar 13, 2014 11:54 am by ac2 | ||
Mk III Build - little help? | 23 | Dingojazz | 2478 | Mon Mar 10, 2014 5:44 pm by stromberg67 | ||
Speaker upgrades | 8 | corndog71 | 4715 | Sun Mar 09, 2014 1:22 am by pigface | ||
Custom Chassis? 1, 2, ... , 5, 6 | 139 | sKiZo | 11739 | Fri Mar 07, 2014 10:33 pm by ac2 | ||
simplifying inputs/outputs on pas3 | 14 | alyosha | 1596 | Fri Mar 07, 2014 2:38 pm by alyosha | ||
two GZ 34 rectifiers | 21 | ac2 | 2768 | Thu Mar 06, 2014 2:41 am by ac2 | ||
DAC for a CD player | 4 | Dave_in_Va | 1299 | Wed Mar 05, 2014 9:47 pm by frank | ||
Can a sound stage be TOO big??? 1, 2 | 31 | Laminarman | 2991 | Wed Mar 05, 2014 1:32 am by deepee99 | ||
SP-14 Voltage Regulator | 4 | mijohn | 1190 | Tue Mar 04, 2014 10:11 pm by pigface | ||
st-70 problem - 2 of 3 preamp tubes won't glow | 1 | slowhandsonfire | 1014 | Tue Mar 04, 2014 7:37 pm by Bob Latino | ||
by-pass switch for thermistor | 15 | Guest | 2929 | Tue Mar 04, 2014 7:06 pm by Guest | ||
The FM-3 Zone | 3 | icky | 2318 | Tue Mar 04, 2014 5:27 pm by Roy Mottram | ||
SP14 or a second ST120 | 15 | Digdug | 2004 | Tue Mar 04, 2014 3:28 pm by pmarcin | ||
Looking for quality KIT DAC 1, 2 | 39 | Maintarget | 4370 | Tue Mar 04, 2014 3:10 pm by pmarcin | ||
SP14 Hum reduction and Chassis Grounding | 3 | mijohn | 3231 | Tue Mar 04, 2014 4:20 am by mijohn | ||
VTA ST120 - is it necessary to power off amp to change speaker wire? | 4 | guentherj2 | 1246 | Sun Mar 02, 2014 4:59 pm by peterh | ||
Switchable Power Supply (110/220V) Support | 5 | PatrickJ | 2183 | Sat Mar 01, 2014 9:21 pm by Alan-14 | ||
I need a null metter | 0 | sailor | 730 | Sat Mar 01, 2014 2:49 pm by sailor | ||
ST35 power transformer running HOT! | 11 | ampgeezer | 3249 | Fri Feb 28, 2014 11:49 pm by Roy Mottram | ||
SP 14 build finally done and.... 1, 2 | 31 | Laminarman | 3627 | Fri Feb 28, 2014 2:10 pm by Laminarman | ||
Dynaco PAS preamps | 18 | Guest | 3852 | Thu Feb 27, 2014 11:39 am by Guest | ||
Hearing test | 10 | deepee99 | 1242 | Thu Feb 27, 2014 3:38 am by deepee99 | ||
Dynakit Mark III w/ Octal Board - Out of the dry dock | 8 | Elrick | 3269 | Wed Feb 26, 2014 8:11 pm by wildiowa | ||
Bias and plate voltage | 5 | mazeeff | 2817 | Tue Feb 25, 2014 10:00 am by mazeeff | ||
Built me a Bucker | 18 | sKiZo | 2277 | Sun Feb 23, 2014 7:22 pm by sKiZo | ||
MK IV Blowing Power Transformers | 11 | Tarazed | 2959 | Fri Feb 21, 2014 8:48 pm by Tarazed | ||
VTA ST-120 and 12BH7's | 5 | Leigh W | 2491 | Tue Feb 18, 2014 9:31 am by Leigh W | ||
Tube but not necessarily audio related - old Heathkit o-scope | 2 | Tom | 1289 | Mon Feb 17, 2014 9:44 am by Tom | ||
Cage Paint | 5 | dmag | 2671 | Sun Feb 16, 2014 8:14 pm by dmag | ||
tube choices | 2 | aliveatfive | 2997 | Sun Feb 16, 2014 6:57 pm by deluxmon | ||
Tube sound terminology | 14 | mazeeff | 1493 | Sun Feb 16, 2014 2:12 pm by Laminarman | ||
Modern Made EL34 (or KT77) for Original ST70 | 17 | BNR_1 | 6062 | Sat Feb 15, 2014 9:19 pm by BNR_1 | ||
new style SP14 chassis | 23 | Roy Mottram | 6441 | Sat Feb 15, 2014 4:28 pm by gener8r | ||
Dynaco SE-10 Equalizer | 3 | Guest | 2286 | Sat Feb 15, 2014 12:17 pm by Guest | ||
PAS3X power switch capacitor | 1 | icky | 882 | Fri Feb 14, 2014 11:15 pm by Bob Latino | ||
Low gain VTA70 driver board...has a 12at7 been tried? | 4 | olds442111 | 1613 | Fri Feb 14, 2014 7:18 pm by olds442111 | ||
The 'Baffling' Revival of the Vinyl L.P. 1, 2 | 25 | deepee99 | 3017 | Fri Feb 14, 2014 7:09 pm by Luddite | ||
Just started an ST-70 kit 1, 2 | 26 | Cubdriver | 4500 | Tue Feb 11, 2014 5:04 pm by Cubdriver |
Sort
Users browsing this forum: 2 Registered, 0 Hidden and 4 Guests
Registered Users: Mr Ridesglide, skriefal
