Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4101 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 856 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1367 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
Replacing tubes. | 21 | Dogstar | 1383 | Sun Oct 29, 2017 7:57 am by Bob Latino | ||
Testing 7199 valves/tubes | 15 | hansfob | 1890 | Fri Oct 27, 2017 6:22 pm by Big Harry | ||
Tubes types/do they make a noticeable difference | 4 | bluemeanies | 1087 | Thu Oct 26, 2017 8:51 pm by bluemeanies | ||
Do you consider VTAST70 "tubey" | 6 | rymi | 1100 | Wed Oct 25, 2017 2:31 pm by Roy Mottram | ||
Robots playing music ? Check out these two videos .. | 10 | Bob Latino | 773 | Tue Oct 24, 2017 3:07 pm by Peter W. | ||
Tube rectified | 12 | Guest | 1537 | Tue Oct 24, 2017 12:46 am by Tubes4ever | ||
following up on biamping, is this a valid concern? | 9 | tajanes | 681 | Mon Oct 23, 2017 5:07 pm by tajanes | ||
Bi-wiring. Bunkum or for real? | 2 | deepee99 | 634 | Mon Oct 23, 2017 4:33 pm by deepee99 | ||
On Off Switch for fuse holder cap. | 0 | Pat R. | 591 | Sat Oct 21, 2017 9:50 pm by Pat R. | ||
VTA ST70 static pop on shutdown | 9 | rymi | 1018 | Fri Oct 20, 2017 1:20 pm by rymi | ||
Zobel Network | 1 | Pillo69 | 956 | Fri Oct 20, 2017 1:02 pm by Peter W. | ||
New Member, New ST120! 1, 2 | 27 | Guest | 2271 | Fri Oct 20, 2017 10:08 am by Guest | ||
Dynaco VTA ST120/Magnapan 1.6 QR ? | 8 | scottlowe76 | 1124 | Fri Oct 20, 2017 2:00 am by j beede | ||
Mechanical hum: power transformer | 2 | 2turbos | 1551 | Wed Oct 18, 2017 8:07 pm by 2turbos | ||
red, yellow and black sec. wires on MKII ot... | 1 | Chris Scott | 603 | Tue Oct 17, 2017 12:33 pm by Peter W. | ||
Blue glow.. | 5 | Ernstmach | 991 | Mon Oct 16, 2017 7:19 pm by Ernstmach | ||
FM-3 or FM-5? | 4 | jrethorst | 1848 | Mon Oct 16, 2017 6:26 pm by Stevedel | ||
Keep pre-amp tubes lit or shut down? | 2 | deepee99 | 789 | Sun Oct 15, 2017 4:18 pm by Roy Mottram | ||
Phono question | 4 | bubbasweet | 800 | Sun Oct 15, 2017 11:52 am by deepee99 | ||
do vta 70 , vta120 sounds the same ??? | 9 | wantech | 1544 | Wed Oct 11, 2017 2:14 pm by Peter W. | ||
Shutdown of preamp - then Thump (not Trump) 1, 2 | 26 | jfine | 1999 | Mon Oct 09, 2017 11:24 pm by Dogstar | ||
M125 anniversary look back | 9 | LeGrace | 1539 | Sun Oct 08, 2017 3:16 pm by deepee99 | ||
A few questions re. restoring a Dynakit mk II | 10 | Chris Scott | 1423 | Fri Oct 06, 2017 12:09 pm by Chris Scott | ||
Isolation Transformer an Option? 1, 2 | 32 | LeGrace | 2189 | Thu Oct 05, 2017 4:48 pm by Peter W. | ||
The Paoli 60M | 7 | Bobzilla | 6090 | Wed Oct 04, 2017 3:45 pm by peterh | ||
An excellent video on turntable set-up | 0 | deepee99 | 581 | Sat Sep 30, 2017 7:16 pm by deepee99 | ||
KT120 vs Shuguang KT88 in my Mark IIIs | 20 | wgallupe | 5812 | Fri Sep 29, 2017 11:07 am by sKiZo | ||
6L6GC to replace EL34 on st70 | 9 | wantech | 3766 | Fri Sep 29, 2017 12:34 am by Tubes4ever | ||
Is the inside of this tube bad, or is it just typical greyish coating? | 7 | jfine | 703 | Thu Sep 28, 2017 2:18 pm by deepee99 | ||
Introductory Hello & My M125 Build 1, 2, 3 | 51 | Denizen | 3129 | Thu Sep 28, 2017 12:18 pm by Denizen | ||
New Guy. Chassis Stand | 12 | matallan | 1180 | Tue Sep 26, 2017 11:05 am by Bob Latino | ||
Are these good mods for a PAS 3x? | 14 | jrethorst | 3399 | Sun Sep 24, 2017 11:01 pm by j beede | ||
Tube #6680 | 3 | DavidR | 791 | Sun Sep 24, 2017 3:24 pm by Bob Latino | ||
Toroidal Versus EI Transformers | 16 | deepee99 | 2556 | Fri Sep 22, 2017 4:25 pm by Tubes4ever | ||
St70 rehab questions | 3 | BudK | 798 | Thu Sep 21, 2017 3:05 pm by Peter W. | ||
Original ST 70 PC3 board 557003 layout? | 5 | stupidhead | 3108 | Thu Sep 21, 2017 8:14 am by stupidhead | ||
a $5000 preamp for $1350 | 11 | Roy Mottram | 3041 | Sat Sep 16, 2017 5:14 pm by Corona | ||
What kind of tubes for the m125 | 11 | bluemeanies | 1320 | Sat Sep 16, 2017 4:55 pm by Corona | ||
Variac's on sale right now at Circuit Specialists in AZ 1, 2, 3 | 72 | Bob Latino | 6006 | Wed Sep 13, 2017 7:59 pm by slate1 | ||
MkIII blown fuse. | 10 | Ernstmach | 1905 | Wed Sep 13, 2017 3:52 pm by Bob Latino | ||
VTA ST-120 Alternative Transformers | 4 | Dogstar | 2333 | Sun Sep 10, 2017 7:42 am by Peter W. | ||
pas power supply question | 3 | mrich | 642 | Sat Sep 09, 2017 9:25 am by Peter W. | ||
Which turntable and cartridge would you keep? 1, 2 | 36 | Dogstar | 2182 | Fri Sep 08, 2017 10:26 pm by Dogstar | ||
VTA PH16 Phono Stage Flexibility | 14 | slate1 | 2794 | Fri Sep 08, 2017 1:33 pm by slate1 | ||
M125 Interconnect Lengths | 2 | Denizen | 795 | Fri Sep 08, 2017 10:52 am by Denizen | ||
Caps PIO K40Y-9 and K42Y-2 | 6 | Pillo69 | 4948 | Thu Sep 07, 2017 7:50 pm by Pillo69 | ||
Metered Variac | 0 | Peter W. | 809 | Wed Sep 06, 2017 1:58 pm by Peter W. | ||
How to properly house-wire your sound system? | 5 | deepee99 | 1527 | Tue Sep 05, 2017 9:05 pm by deepee99 | ||
KT88 poor service life | 23 | LeGrace | 1525 | Mon Sep 04, 2017 7:34 pm by jfine | ||
Iceland: time for a meet-up? | 7 | deepee99 | 760 | Fri Sep 01, 2017 11:59 am by deepee99 |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 3 Guests
Registered Users: None
