Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4150 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 881 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1379 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
shielded audio wire instead of twisted | 1 | Guest | 1127 | Tue Feb 11, 2014 2:55 pm by Zimmer64 | ||
Right Angle Connectors | 8 | Brap | 1371 | Tue Feb 11, 2014 3:33 am by deepee99 | ||
Tube heater delay problem | 2 | Rich | 983 | Sun Feb 09, 2014 3:19 pm by Rich | ||
ST-120 Assembly | 8 | Sal | 2037 | Fri Feb 07, 2014 3:42 pm by sKiZo | ||
For real men (or very hairy women) | 4 | deepee99 | 1782 | Fri Feb 07, 2014 12:16 pm by arledgsc | ||
Balanced Triodes | 4 | polarflux | 1198 | Fri Feb 07, 2014 10:35 am by Tiziano73 | ||
6L6 IN ST120? | 2 | sKiZo | 1677 | Thu Feb 06, 2014 4:55 pm by sKiZo | ||
Tun-Sol Kt-150 tubes | 4 | Brap | 1685 | Wed Feb 05, 2014 2:26 pm by deepee99 | ||
ST-70 new center tube | 0 | baddog1946 | 1018 | Wed Feb 05, 2014 1:12 pm by baddog1946 | ||
Line voltage and bias | 2 | wildiowa | 1315 | Tue Feb 04, 2014 8:18 pm by sKiZo | ||
richie havens | 3 | wedg714 | 1029 | Tue Feb 04, 2014 10:54 am by arledgsc | ||
VTA ST 120 Pre Amp Tube Options | 1 | EddieGnz1 | 1313 | Mon Feb 03, 2014 3:54 pm by sKiZo | ||
What to do with 16 Ohm tap | 3 | daveshel | 1128 | Mon Feb 03, 2014 12:54 pm by anbitet66 | ||
VTA-SP-14 Hum | 8 | Leigh W | 2674 | Sun Feb 02, 2014 11:19 pm by Roy Mottram | ||
Replacing PAS volume pot, but strange curiosity about wiring it up.... | 7 | fedoragent | 3087 | Sun Feb 02, 2014 10:28 pm by fedoragent | ||
PH-10 Trimpots Question | 2 | allenmmusic10003 | 738 | Sun Feb 02, 2014 7:34 pm by allenmmusic10003 | ||
Dynaco Mk IV's | 7 | harpy | 2072 | Sun Feb 02, 2014 1:45 am by harpy | ||
Pas 3 Aikido hum and scratchy volume | 5 | gdlen1 | 1561 | Sat Feb 01, 2014 3:56 pm by gdlen1 | ||
Mark II Power Transformer | 2 | Backpacker85 | 963 | Sat Feb 01, 2014 2:34 pm by DynakitParts | ||
PAS-2 Volume Pot and Cap Replacement - Safety Question | 2 | fedoragent | 992 | Sat Feb 01, 2014 1:49 am by fedoragent | ||
Things to look for when a tube blows? | 3 | polarflux | 1135 | Fri Jan 31, 2014 11:58 am by zx | ||
no power from TDR board | 3 | oldvstar | 965 | Thu Jan 30, 2014 3:57 pm by Bob Latino | ||
new octal vta | 1 | kost | 1394 | Thu Jan 30, 2014 12:10 pm by arledgsc | ||
Driver tubes | 3 | corndog71 | 2738 | Wed Jan 29, 2014 6:54 pm by sKiZo | ||
ST-70 Input Signal | 3 | mazeeff | 1633 | Tue Jan 28, 2014 4:36 pm by sKiZo | ||
First Timer...Troubleshooting 1, 2 | 37 | DrZ123 | 4012 | Mon Jan 27, 2014 9:23 pm by arledgsc | ||
quad cap quandry | 2 | Guest | 1296 | Sat Jan 25, 2014 5:29 pm by DarthBubba | ||
VTA-70 and SP-10 impressions | 10 | dougmon | 2907 | Thu Jan 23, 2014 11:57 pm by dougmon | ||
Rectifier Tube sparking - blown fuse | 12 | photoenergy | 3459 | Thu Jan 23, 2014 11:10 am by arledgsc | ||
Fabrication of Vacuum Tubes | 1 | fedoragent | 929 | Wed Jan 22, 2014 4:05 pm by sKiZo | ||
Aluminum Extrusions for Dynaco Face Plates | 17 | TN Allen | 2950 | Wed Jan 22, 2014 4:02 pm by sKiZo | ||
ST70 Bias exceed 0.6 volt and raise quickly on one channel after install the 3 12AU7 tubes | 5 | EugeneHiFi | 1360 | Wed Jan 22, 2014 11:48 am by arledgsc | ||
PH16 Pictures | 19 | turbotoy | 5185 | Tue Jan 21, 2014 9:19 pm by turbotoy | ||
6N6P for monoblocks M-125 | 3 | buchela | 2347 | Tue Jan 21, 2014 12:54 pm by sailor | ||
Anyone installed standard MK III boards into MK IV amps? Could I see pictures of your work? | 1 | howlin' hoosier | 796 | Mon Jan 20, 2014 9:44 pm by DynakitParts | ||
Mark IV power transformer running hot?? Any ideas | 22 | Tanner | 4572 | Mon Jan 20, 2014 10:54 am by howlin' hoosier | ||
Rolling 6922's in PH12? | 5 | kevco | 1444 | Sun Jan 19, 2014 9:22 pm by guentherj2 | ||
Just Lost a KT-88 in the ST-120 | 18 | arledgsc | 2221 | Sun Jan 19, 2014 12:22 pm by arledgsc | ||
Hello from Louisiana | 6 | olds442111 | 1013 | Sun Jan 19, 2014 4:00 am by olds442111 | ||
Election Cartridge | 6 | Pillo69 | 1359 | Fri Jan 17, 2014 2:28 pm by Roy Mottram | ||
Cryogenically treated tubes | 3 | ramon68 | 2843 | Thu Jan 16, 2014 2:07 am by ArlanB | ||
Dynaco SCA-35 help | 4 | Babgrip | 1205 | Tue Jan 14, 2014 3:37 pm by sKiZo | ||
First Timer...Seriously | 24 | DrZ123 | 2859 | Tue Jan 14, 2014 10:52 am by corndog71 | ||
Music server question | 20 | Laminarman | 2173 | Mon Jan 13, 2014 7:15 am by Laminarman | ||
Dynaco Bar...Beers & Wings | 1 | DynakitParts | 1085 | Sun Jan 12, 2014 9:10 pm by sKiZo | ||
iZotope vinyl - "the ultimate low-fi weapon" | 11 | Bob Latino | 1274 | Sun Jan 12, 2014 3:45 am by Blitzen | ||
Philips 5814 - 12AU7 | 5 | Tom | 1742 | Sat Jan 11, 2014 7:36 am by Tom | ||
is 400 volt k40y9 .22mfd ok to use in mark iii driver board or need 600 volt | 2 | daniel a | 1202 | Fri Jan 10, 2014 8:33 pm by Bob Latino | ||
is it ok to use 0.47 mfd coupling caps on stock Mark iii driver board | 0 | daniel a | 928 | Fri Jan 10, 2014 8:23 pm by daniel a | ||
Favorite driver combo? | 23 | Maintarget | 3142 | Thu Jan 09, 2014 8:30 pm by deepee99 |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 3 Guests
Registered Users: None
