Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4096 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 854 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1366 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
ST70 Possible power transformer issue - request for values - SOLVED | 0 | jrubin | 606 | Thu Apr 04, 2019 7:22 pm by jrubin | ||
Speaker Wire from Roy | 6 | Guest | 1303 | Tue Apr 02, 2019 10:46 am by 10-E-C | ||
I'm damaged goods. | 3 | bbqjoe | 736 | Sun Mar 31, 2019 3:01 pm by corndog71 | ||
VTA ST-120 with Maggie 1.7i | 15 | ImFritz | 1719 | Sat Mar 30, 2019 12:12 pm by deepee99 | ||
60 Hz Hum, and What it Feels Like | 3 | Peter W. | 604 | Fri Mar 29, 2019 3:34 pm by deepee99 | ||
Prefered rectifier tube for VTA ST-120 | 2 | ImFritz | 1579 | Fri Mar 29, 2019 2:09 pm by ImFritz | ||
SP14 tube layout. | 8 | FearOfMusic | 1971 | Wed Mar 27, 2019 12:28 am by Kentley | ||
ANK DAC 4.1 Build 1, 2, 3 | 62 | cci1492 | 6040 | Tue Mar 26, 2019 7:23 pm by audiobill | ||
Rules of thumb for testing tube amps | 2 | Midwestside | 913 | Mon Mar 25, 2019 7:13 pm by Midwestside | ||
How can I play digital files? | 7 | solderblob | 802 | Sun Mar 24, 2019 11:55 pm by buchela | ||
Rectifier troubleshooting | 10 | steve46 | 908 | Sun Mar 24, 2019 11:04 pm by Tubes4ever | ||
VTA ST 70 20 AWG tinned copper core wire question | 8 | Midwestside | 1345 | Thu Mar 21, 2019 9:30 pm by Midwestside | ||
Mullard GZ33 NOS tube | 16 | ImFritz | 3312 | Thu Mar 21, 2019 8:42 pm by ImFritz | ||
Dynaco A-25 speakers. | 9 | FearOfMusic | 3406 | Thu Mar 21, 2019 5:54 pm by martin | ||
Rewinding Dyanco power transforemrs | 2 | WLT | 987 | Thu Mar 21, 2019 9:52 am by 10-E-C | ||
"Yellow sheet" diode mode, WZ68 copper cap, and start-up arcing | 4 | eickmewg | 1414 | Wed Mar 20, 2019 1:53 pm by Peter W. | ||
e80cc in center position on st-70 | 9 | bozo | 2535 | Wed Mar 20, 2019 1:49 pm by spantou | ||
Speakers and your tube amp? | 6 | Guest | 1477 | Tue Mar 19, 2019 4:58 pm by WLT | ||
Ordered a matched quad of TAD KT88-STR's to drop in the ST-120.... any advice? | 5 | slate1 | 823 | Tue Mar 19, 2019 3:33 pm by MarcVBelgium | ||
Bent / Splayed Power Tube Pins KT88 - Octal Tube Pin Straightener | 7 | aguaazul | 910 | Tue Mar 19, 2019 2:09 pm by sKiZo | ||
Contact cleaner | 5 | wildiowa | 895 | Tue Mar 19, 2019 9:52 am by Peter W. | ||
PAM-1 filaments aren't lighting | 3 | antsap | 577 | Sat Mar 16, 2019 7:43 am by Peter W. | ||
2018 SP14vP Build Pics - updated to v2.0 | 8 | Jedidiah | 2048 | Wed Mar 13, 2019 9:00 pm by pedrocols | ||
infamous Dave Lucas " hand wound" PA060 transformer | 2 | Antonn | 1006 | Wed Mar 13, 2019 9:32 am by DynakitParts | ||
The Old A-470's cloth lead vs. new production outputs ... | 9 | wolverine | 9159 | Mon Mar 11, 2019 3:26 pm by Peter W. | ||
When to replace caps, and which ones? | 4 | arley | 988 | Sun Mar 10, 2019 3:30 pm by arley | ||
too much gain? | 6 | buschfsu | 1019 | Sat Mar 09, 2019 12:26 am by buschfsu | ||
VTA ST-120 and Variac 5 amp fuse Help appreciated | 22 | ImFritz | 1810 | Thu Mar 07, 2019 7:09 pm by ImFritz | ||
coupling cap on SP 14 | 10 | bscp | 1176 | Thu Mar 07, 2019 12:25 am by bscp | ||
ST70, Gold Lion KT-77's low bias | 22 | mmmalmberg | 3439 | Wed Mar 06, 2019 7:04 pm by DC92 | ||
Random Thoughts on the Care and Feeding of Audio Equipment - Tube-Centric | 0 | Peter W. | 819 | Wed Mar 06, 2019 3:34 pm by Peter W. | ||
New tubes too hot? | 6 | Pad_X | 1249 | Mon Mar 04, 2019 8:59 pm by Wharfcreek | ||
SP 14/ PH 14 cooling space? | 2 | Dave_in_Va | 607 | Sun Mar 03, 2019 5:40 pm by Dave_in_Va | ||
VTA ST-120 and ohms | 11 | coolhandjjl | 3266 | Sun Mar 03, 2019 3:39 pm by Bob Latino | ||
ST-120 Power Switch Move | 18 | jimmeq | 1723 | Sat Mar 02, 2019 4:05 pm by deepee99 | ||
Xlr inputs for vta st 70 | 7 | islanddave | 921 | Sat Mar 02, 2019 2:45 pm by deepee99 | ||
Line Noise Suppression | 8 | Peter W. | 967 | Sat Mar 02, 2019 2:27 pm by aguaazul | ||
Vacuum Tube Keyway Replacement Saver Fix Repair Broken Center Guide-Post | 4 | aguaazul | 1141 | Sat Mar 02, 2019 12:05 am by aguaazul | ||
Chasing Hum with a "new" old ST-120 - solved ! 1, 2 | 47 | vizsla23 | 2332 | Fri Mar 01, 2019 9:01 am by Peter W. | ||
7199 vs 6gh8 vs 12au7 vs 6sn7 for st70 ???? | 17 | wantech | 5950 | Tue Feb 26, 2019 1:15 pm by Brap | ||
Original Dynaco st70 High bias one side | 19 | tubefan9 | 1991 | Mon Feb 25, 2019 7:04 pm by Bob Latino | ||
Tube and solid-state amps connected to same speakers - how to toggle? | 20 | deepee99 | 1630 | Sun Feb 24, 2019 11:13 am by jasn54 | ||
Sourcing 20 AWG solid core 600V wire to install the Time Delay Board 1, 2 | 26 | vizsla23 | 1599 | Sat Feb 23, 2019 5:41 pm by matallan | ||
I let the smoke out. 1, 2 | 35 | bbqjoe | 2622 | Wed Feb 20, 2019 10:20 pm by bbqjoe | ||
New to tube amplification | 5 | aCMD | 603 | Wed Feb 20, 2019 6:37 pm by aCMD | ||
How I mounted the display module on my SP 14 | 2 | Pooch | 795 | Tue Feb 19, 2019 4:24 am by Pooch | ||
M125 Builds for a Novice | 12 | ryaneirich | 2431 | Sun Feb 17, 2019 10:24 am by crkohut | ||
Can't bias 6L6 low enough in ST-70 with Dynakitparts bias mod. | 4 | intotubes | 1099 | Sat Feb 16, 2019 2:13 pm by intotubes | ||
ST-70 and Sonus Faber | 3 | Brap | 710 | Fri Feb 15, 2019 10:41 pm by StevieRay | ||
More pictures | 2 | Pad_X | 632 | Fri Feb 15, 2019 6:54 pm by Pad_X |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 4 Guests
Registered Users: None
