Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4096 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 855 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1366 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
SCA 35 Iron | 10 | Peter W. | 2025 | Fri Aug 19, 2016 8:07 pm by Flyquail56 | ||
Don't care for SS finish | 2 | novisnick | 940 | Fri Aug 19, 2016 3:00 pm by novisnick | ||
Interesting discussion on speaker cable snake-oil 1, 2 | 42 | deepee99 | 3991 | Thu Aug 18, 2016 9:00 pm by Dogstar | ||
Anyone figured out how to match Dynaco's textured paint? | 10 | j beede | 2480 | Wed Aug 17, 2016 9:13 am by Peter W. | ||
The Pursuit of Power | 4 | Kentley | 952 | Tue Aug 16, 2016 1:22 pm by GP49 | ||
Yet another new guy.....uffa! | 10 | cci1492 | 1062 | Tue Aug 16, 2016 8:28 am by cci1492 | ||
High Voltage Quad Cap and Mk3s To Replace or Not... | 23 | bubbasweet | 2273 | Mon Aug 15, 2016 3:23 pm by Peter W. | ||
Suggested Multi-lug Can Cap Values for PS-1 PAM-1 and PAS-3 | 11 | bubbasweet | 1960 | Mon Aug 15, 2016 11:39 am by bubbasweet | ||
Painting transformers on tube amps | 2 | Bob Latino | 3695 | Sat Aug 13, 2016 6:47 am by LeGrace | ||
Advice on Eico 666 tube tester | 1 | Dave_in_Va | 1201 | Fri Aug 12, 2016 2:54 pm by Peter W. | ||
PAS Rebuild | 23 | daveshel | 3224 | Thu Aug 11, 2016 7:35 am by Peter W. | ||
CD vs VINYL vs STREAMING | 21 | bluemeanies | 1513 | Thu Aug 11, 2016 7:28 am by Peter W. | ||
Just when you think you've seen it all . . . | 6 | deepee99 | 2616 | Wed Aug 10, 2016 3:54 pm by Peter W. | ||
0000 Steel wool and wd40 on Dynaco original Nickel Chrome Chassis ok? | 6 | bubbasweet | 1920 | Wed Aug 10, 2016 2:29 pm by Peter W. | ||
ST-120 Tune Up | 8 | arledgsc | 1606 | Wed Aug 10, 2016 12:19 pm by arledgsc | ||
Ventilation space. | 8 | Dogstar | 1407 | Mon Aug 08, 2016 10:52 pm by Dogstar | ||
Higher filer cap effect on Mk3 | 5 | bubbasweet | 948 | Thu Aug 04, 2016 1:33 am by bubbasweet | ||
VTA Tube Buffer | 5 | wgallupe | 1827 | Wed Aug 03, 2016 9:14 am by Dogstar | ||
Turntable ground question | 2 | bubbasweet | 884 | Mon Aug 01, 2016 3:37 pm by deepee99 | ||
Anyone have or know where to get the original Dynaco Vintage Carbon Resistors | 11 | bubbasweet | 1204 | Sat Jul 30, 2016 6:29 pm by bubbasweet | ||
Replacement socket recommendations | 8 | James_Weir | 1882 | Fri Jul 29, 2016 6:50 pm by bubbasweet | ||
Some Questions about VTA Preamps | 9 | TorontoDave | 1846 | Fri Jul 29, 2016 4:14 pm by Rabindu | ||
One last MK3 Diode mod Bias question | 2 | bubbasweet | 786 | Fri Jul 29, 2016 3:27 pm by bubbasweet | ||
Bi-amping with two VTA amps. | 17 | Dogstar | 2103 | Wed Jul 27, 2016 3:59 pm by arley | ||
VTA assembly manual | 8 | James_Weir | 6471 | Mon Jul 25, 2016 2:29 pm by Roy Mottram | ||
Turret? Or is there a better way? | 1 | j beede | 759 | Sun Jul 24, 2016 9:31 pm by kaner | ||
Vintage Vacuum Audio - schematics, brochures, manuals ... | 0 | Bob Latino | 907 | Sat Jul 23, 2016 12:20 pm by Bob Latino | ||
The great Sino-Soviet cook-off | 21 | deepee99 | 1553 | Fri Jul 22, 2016 12:32 am by deepee99 | ||
Dynaco Mark III Rebuild: low output problem | 13 | steve's garage | 1994 | Thu Jul 21, 2016 10:56 pm by Roy Mottram | ||
Dynaco CDV-1 manual needed | 0 | BSpaaudio | 804 | Thu Jul 21, 2016 11:40 am by BSpaaudio | ||
My new SP13! | 6 | corndog71 | 2122 | Thu Jul 21, 2016 11:20 am by corndog71 | ||
MK3 Resistor question and a couple other questions | 12 | bubbasweet | 2084 | Wed Jul 20, 2016 9:20 am by bubbasweet | ||
Glass piece inside output tube and tube placement | 2 | James_Weir | 734 | Mon Jul 18, 2016 3:52 pm by James_Weir | ||
Dynaco MK3 Original Circuit board Component layout. | 3 | bubbasweet | 1877 | Mon Jul 18, 2016 12:43 pm by bubbasweet | ||
Great eBay vendor for aluminum knobs, feet and other hardware | 1 | vtshopdog | 781 | Sat Jul 16, 2016 12:01 am by pedrocols | ||
VTA ST-120 Problems - solved ! | 5 | stewdan | 2712 | Wed Jul 13, 2016 2:59 pm by Dale Stevens | ||
Favorite 12AU7 types ? 1, 2 | 32 | scottlowe | 11264 | Sun Jul 10, 2016 5:04 pm by deepee99 | ||
Some of my first audio gear - photo .. 1, 2 | 25 | Bob Latino | 2898 | Sun Jul 10, 2016 12:45 pm by arledgsc | ||
VTA tube preamps | 6 | Roy Mottram | 1986 | Sat Jul 09, 2016 10:16 pm by jimmytamp | ||
RCA blackplate tubes ... Do the black plates make a difference ? | 2 | Bob Latino | 1205 | Sat Jul 09, 2016 5:29 pm by deepee99 | ||
Chinese Shuguang/PSVane tube low-down | 12 | deepee99 | 7708 | Fri Jul 08, 2016 10:00 pm by sKiZo | ||
Paoli 60M / VTA ST-120 mashup | 13 | jho | 2020 | Wed Jul 06, 2016 11:00 pm by Kentley | ||
SP12/PH12 Phase Correct? | 5 | kevco | 1080 | Mon Jul 04, 2016 7:42 am by WntrMute2 | ||
Tube Crossover Board Mounting - PS section front or back? | 1 | aguaazul | 967 | Sat Jul 02, 2016 1:34 pm by Roy Mottram | ||
For streaming junkies, this is from this a.m.'s Wall Street Journal | 0 | deepee99 | 618 | Fri Jul 01, 2016 2:30 pm by deepee99 | ||
Amplifier hour meter - very useful | 6 | Bob Latino | 1996 | Tue Jun 28, 2016 8:52 pm by Kentley | ||
driver tubes dont light up after hookup wire replacement in mk3[PHOTOS] | 18 | gruvlad | 1090 | Sat Jun 25, 2016 2:04 pm by gruvlad | ||
A new ST-120 review | 7 | audiobill | 1450 | Thu Jun 23, 2016 8:37 pm by jasn54 | ||
Charles Rodrigues "Total Harmonic Distortion" cartoons from Stereo Review | 3 | GP49 | 8450 | Wed Jun 22, 2016 9:15 pm by deepee99 | ||
PAS 2/3/3X input selector wiring | 1 | j beede | 1612 | Mon Jun 20, 2016 4:15 pm by Guest |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 3 Guests
Registered Users: None
