Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4146 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 878 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1377 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
MIA MK III Boards from Tubes4hifi? | 5 | tubed1 | 980 | Sat Sep 01, 2018 12:17 pm by Roy Mottram | ||
SCA-35 squeals when powering up | 5 | dockbuster | 573 | Sat Sep 01, 2018 2:22 am by peterh | ||
Best SS Dyna preamp? | 5 | wildiowa | 1774 | Thu Aug 30, 2018 5:05 pm by Dale Stevens | ||
Mil spec bias pot | 3 | ttownscott | 655 | Tue Aug 28, 2018 7:43 pm by DynakitParts | ||
Exciters used for speakers | 8 | CNCfan | 685 | Tue Aug 28, 2018 1:17 pm by Peter W. | ||
Which hammond power transformer for a ST70 clone | 7 | starwatcher | 5757 | Tue Aug 28, 2018 12:59 am by starwatcher | ||
VTA ST-70 strange initial start-up | 18 | Brap | 1543 | Fri Aug 24, 2018 11:45 am by Brap | ||
On Pre-Amps 1, 2 | 37 | Peter W. | 3299 | Fri Aug 24, 2018 10:28 am by dmagazz | ||
What to do with the front panel octals after adding autobias board. | 2 | dacer38 | 794 | Fri Aug 24, 2018 10:05 am by peterh | ||
5R4WGB rectifier tube | 4 | billd | 4507 | Wed Aug 22, 2018 4:19 am by billd | ||
Auto-bias Upgrade Decision | 21 | Falcon4646 | 3418 | Tue Aug 21, 2018 1:37 am by CNCfan | ||
Revived ST-70 | 0 | pmorrissey | 619 | Mon Aug 20, 2018 7:53 pm by pmorrissey | ||
Can you hear the difference in audio quality? | 3 | Zimmer64 | 1055 | Thu Aug 16, 2018 6:01 pm by sKiZo | ||
On the use of a preamp to improve sound quality with VTA70 1, 2, ... , 5, 6 | 148 | rjpjnk | 7689 | Tue Aug 14, 2018 11:39 pm by corndog71 | ||
PAS-3 I replaced the selector switch and messed something else up. | 2 | JohnM24018 | 505 | Tue Aug 14, 2018 3:27 pm by j beede | ||
ST-70 Volume control nut | 0 | Brap | 525 | Mon Aug 13, 2018 11:52 am by Brap | ||
Power Tubes | 2 | bluemeanies | 1153 | Mon Aug 13, 2018 8:39 am by bluemeanies | ||
Cables Make a Difference | 13 | VTHokie83 | 1855 | Mon Aug 13, 2018 8:31 am by Peter W. | ||
Were Audio Research and tubes4Hifi (VTA) related at one point? | 1 | rjpjnk | 980 | Sun Aug 12, 2018 9:49 pm by Bob Latino | ||
power consumption | 19 | dmagazz | 2143 | Sun Aug 12, 2018 2:52 pm by dmagazz | ||
Posting a PDF or Text File attachment | 2 | jwb474 | 438 | Sun Aug 12, 2018 12:35 pm by Bob Latino | ||
st-120 unbalanced L-R output ? | 10 | tajanes | 873 | Thu Aug 09, 2018 9:19 pm by tajanes | ||
Heathkit tube checker specs | 3 | baddog1946 | 2009 | Tue Aug 07, 2018 6:05 pm by baddog1946 | ||
eBay, Already! 1, 2 | 25 | Peter W. | 2021 | Tue Aug 07, 2018 10:14 am by dmagazz | ||
better port for usb soundcard | 0 | dmagazz | 517 | Mon Aug 06, 2018 7:18 pm by dmagazz | ||
Speaker posts | 2 | musicgeorge11 | 789 | Sat Aug 04, 2018 8:12 am by musicgeorge11 | ||
Hello from a Tube Wanna Be.. Yet Another Rectifier Question! | 10 | Itchy | 1365 | Wed Aug 01, 2018 10:05 pm by Tubes4ever | ||
Is this speaker selector switch save with the VTA ST-120? | 6 | almonds | 896 | Wed Aug 01, 2018 2:34 pm by jimmeq | ||
M125's + Bucker Update | 4 | LeGrace | 935 | Tue Jul 31, 2018 6:50 pm by CletusB | ||
Distortion and Hum ??? | 16 | jimmeq | 1588 | Thu Jul 26, 2018 3:11 pm by peterh | ||
Running a PH-16 into an ST-120 with the 21 step attenuator in phono only system. Any benefit to a preamp? | 11 | seeirwin | 795 | Wed Jul 25, 2018 1:40 pm by Roy Mottram | ||
Best audio from your computer? 1, 2, 3 | 63 | SUNNFRK | 4862 | Wed Jul 25, 2018 10:44 am by solderblob | ||
12AU7W / 6189 Hum | 3 | jimmeq | 564 | Fri Jul 20, 2018 1:37 pm by jimmeq | ||
.047uf 630v caps? on driver board. | 7 | dmagazz | 1034 | Thu Jul 19, 2018 9:31 pm by dmagazz | ||
How should I punch 3" by 3" holes in the original ST-70 cage for additional ventilation? 1, 2 | 31 | Kentley | 2186 | Mon Jul 16, 2018 10:30 pm by Kentley | ||
Rectifier damaged? | 5 | hwaitung | 890 | Mon Jul 16, 2018 9:36 pm by sKiZo | ||
cool RCA tube manufacture video(how its made) | 7 | dmagazz | 700 | Sun Jul 15, 2018 7:01 pm by dmagazz | ||
good read on the st 70 i found ( the inside story dynaco) | 2 | dmagazz | 711 | Tue Jul 10, 2018 3:42 pm by dmagazz | ||
Silver Wire Interconnects 1, 2, 3, 4 | 87 | Kramer | 4428 | Tue Jul 10, 2018 3:33 pm by dmagazz | ||
PH-16 Issues | 12 | thermionicvinyl | 1197 | Mon Jul 09, 2018 12:43 pm by Peter W. | ||
6GH8 / 6EA8 | 2 | Pillo69 | 929 | Wed Jul 04, 2018 7:44 pm by Pillo69 | ||
Is there any finer tube than a GEC KT88? | 21 | deepee99 | 4354 | Wed Jul 04, 2018 5:01 pm by Guest | ||
Popping/Crackling coming from VTA 120 (Not the speakers) | 6 | Dneu2011 | 785 | Tue Jul 03, 2018 9:55 pm by Dneu2011 | ||
voltage reading results are in, changed selenium,changed quad cap and driver board caps . | 0 | dmagazz | 680 | Fri Jun 29, 2018 5:37 pm by dmagazz | ||
ST-120 Issues | 12 | thermionicvinyl | 860 | Fri Jun 29, 2018 3:54 pm by thermionicvinyl | ||
The (hopefully) future of electricity! | 3 | corndog71 | 766 | Fri Jun 29, 2018 9:08 am by Peter W. | ||
ok..think im sorta bamboozled! | 5 | dmagazz | 1082 | Wed Jun 27, 2018 8:15 pm by dmagazz | ||
VTA ST-120, Decade of enjoyment. | 2 | ArlanB | 710 | Tue Jun 26, 2018 9:52 pm by ArlanB | ||
quad bias control ? | 5 | dmagazz | 957 | Tue Jun 26, 2018 8:10 pm by dmagazz | ||
Protect your "package" .. There truly is something new every day .. | 7 | Bob Latino | 1000 | Mon Jun 25, 2018 7:12 pm by Kentley |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 2 Guests
Registered Users: None
